SOURCE: I need a free download of Integrated Intel Graphics Accelerator
This should be a link to your drivers. :)
HP/Compaq Intel Integrated Video Driver
SOURCE: can i get audio and video drivers for hp compaq
Yes you can!
You did not mention which Operating system you are using, so you have to take the last steps yourself. But easy enough...
!!! HP does not provide graphic drivers for Windows Vista. In that case you have to find the manufacturer for your display and see if they offer drivers for Vista.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
SOURCE: picked up a HP dc7100 but will not boot from sata
You should have an option on the dc7100 in bios to enable sata in the devices section. Mine always worked fine with sata. If nothing else works remove the security chip, reset the cmos and reboot with the Hard Drive connected and it should connect. If that doesn't work Try flashing the bios just in case it got corrupted.
SOURCE: 917-Front Audio Not Connected Problem with
Please connect front audio cable with motherboard in the a audio port of motherboard.If we work with sound card then connect front audio cable with sound card.
SOURCE: hp compaq dc7100 cmt can't
9 beeps means that the input voltage to the PC's power supply is incorrect, have you changed the switch at the back of the PC from 110 to 240v or vice versa. If the PC was not bought in the UK then it may be set to 110v in which case the voltage selector at the back of the PC needs to be changed to 240v. If there is no voltage selector would recommend changing the power supply.
If by changing the selector to the correct voltage it still beeps 9 times you are looking at a new power supply unit which you can buy from HP at a high cost or buy a used one from:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160617535239
Hope this helps!!!
On the desktop and workstation models, the connector is located under the drive bay on the right hand side of the computer.
In order to recover the system you should remove the TPM module and re-install the OS.
banner_header
VERSION: 2.1.8 Rev. A134 views
