I am getting E005 Error
SOURCE: Error Code E005
Have to reset the cleaning web counter and error. Press *, 2&8, * to enter service mode. (*28*). Highlight COPIER, select COUNTER, select MISC. select CLEANING_WEB and press C on the keypad to clear the counter. Press reset to get back to main service menu, highlight FUNCTION. Select CLEAR. Highlight ERR and press OK. Switch machine OFF/ON. Hope this helps, let me know?
SOURCE: error code E005
if your machine is giving E-005 that means your fixing assembly (fuser cleaning web is not detecting) is bad.
go in service mode by pressing additional fuction + 2 & 8 + again press addtional function
If you find that the E005 code won't reset after replacing the Web, and clearing both web counters in service mode, <COPIER>COUNTER>MISC>FIX-WEB> and <COPIER>COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode <COPIER>FUNCTION>CLEAR>ERR>.
enjoy
SOURCE: i am getting error code e005 0100 how do i reset
E005 Error code details
Main Cause The fixing web has been taken up. The fixing web length sensor (PS45) is faulty. The DC controller PCB is faulty.
Mode of Detection
0000 The length of fixing web that has been taken up is in excess of the specified length.
Caution After replacing the fixing web, be sure to reset the two web counters in service mode: COPIER>COUNTER>MISC>FIX-WEB and COPIER>COUNTER>DRBL-1>FX-WEB.
SOURCE: I have replaced le fusing
You have to get into service mode and go to the counters and go to the web counter and reset it. Also, You may want to go to the Funcation mode and reset the error codes also. To lock the counters, turn the main power switch OFF then back ON.
