HP CQ60 Magnifier SW check follow:
1. check magnifier item locate at middle down side (under the HP LOGO ) of lcd panel, you can use screw drive touch there it will be sticky. if it not sticky there---the magnifier item could be removed or lost the function, you need to open the panel to recover this function. if it works well to go next
2) the magnify receiver is located at keyboard frame top middle ( above the power switch) where is a small board in the back side. if you put any magnify stuff on the top near the power switch, laptop will go to sleep statue. if it not works, the magnifier sensor lost function, it need to repair or change the board,
hope my experience help to you!
AKVIS.comhttps://akvis.com > magnifier
With AKVIS Magnifier AI, you can create a high-quality enlarged image from a small one. The program allows you to increase the image size up to 800%.
It's a problem with your display drivers. What make and model is your laptop? What company makes it? Go to that company's website, and search for drivers, it's usually under the support page of most manufacturers websites. Find your model laptop (Usually identifiable on a sticker on the bottom of the laptop) and get the display, video, or graphics drivers. Install them, and your resolution will be back to normal.
task manager will come (or you have to select Task Manager) in it go to the tab named Processes, find one with the name Magnify.exe then right click on it and select End Process.
Notes A message box with a link to more information about Microsoft Magnifier may appear. To close the box, select OK. To use Magnifier but hide the Magnifier Settings dialog box, select the Minimize button. To turn off Magnifier, in the Magnifier Settings dialog box, select the Exit button
go to start all programes then to accessories. then to accessibilitys and click on narrater or magnifier. and unmark show magnifier.for narrater click exit
