HP LaserJet 3030 All-In-One Printer Logo
Jessica Pritchard Posted on May 04, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
COMM ERROR CODES - HP LaserJet 3030 All-In-One Printer
Mario van Limburg
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 156 Answers
  • Posted on May 04, 2015
Mario van Limburg
Expert
Level 2:
New Friend:
Cheetah:
Answers
156
Questions
0
Helped
58770
Points
418
Yes and explain. what equipment, type, problem, errocode,
most com ports are using
com 1 (normally the mouse on older pc)
com 2 in the past communication port
com 3 usually to convert to other kinds of ports
you can rearrange these ports in the hardware settings list off you're pc, windows take some time to accept it. if you change you're port think about the consequences.
2answers
2008 ford e250 4.6L - has a yes crank - but no fire condition! 26k original miles
Have you disconnected the battery recently?
Immobiliser issue.
How to correct Tread climber TC5500 error code NIPP COMM (Belt Shut Down).
If you wiah to get some details about treadmill error codes and solutions then check the following link
http://electro-medical.blogspot.com/
Please, how can I solve the fault code 19, Master COMM. On my Electrolux W4240H washing machine. All the engineer u contacted didn't get it. Please, help.
Error code 19, MASTER COMM.
Communication with superior system has been broken. The cause can be an error in the network connections, damaged cable, defective monitoring system, etc.
Action: • Contact the supplier of the monitoring system for possible causes of the monitoring system not communicating.
Dado
I have a Bowflex TC5500 When I tried to use today, I got a error message on display that says: ERROR Belt Shutdown error code: NIPP COMM Error
LUBE THE DECK BELT, INMEDIATELY THIS HAPPEN BECAUSE THE LACK OF MAINTENANCE, ACCORDING THE SCHEDULE MAINTENANCE, READ YOUR OWNER MANUAL OR DOWNLOAD FROM WWW.ICONSERVICE.COM
GOD BLESS YOU
5helpful
I have error codes flashing on my thermostat..it is an american standard model the manual for the therm. has ACOT900AC43UA on front..says to find addedum 18-HD32D2-1/69-2009 for codes i cannot find it...
Error codes from American Standard Pub 18-HD32D2-8, which is a one-sheet document that came with my American Standard air-conditioner:
29 = not listed
129 = not listed
80 = HPCO Fault - problem is in outdoor unit - Desscription: High Pressure Monitor Fault (hard lock out, cycle power to reset)
91 = Communication Inactive Fault - problem is in air handler - Descriptions - COMM Bit Master Clock Error, COMM Heat/Cool Demand Error, Serial Motor Communication Inactive Error
91 = Communication Fault - problem is in furnace - Descriptions: Blower motor no COMM response, Inducer motor no COMM response, Loss of heat/cool demand, Loss of clock signal
91 = Communication Fault - problem is in outdoor unit - Descriptions: Loss of Heat/Cool Demand Message (COMM), Loss of Bit Master (Clock Signal)
91 = Communication Fault - Description: Comm line is dead and no bits have been received.
By the way, I do not recommend American Standard. I've had mine 14 months and it just blew up - the entire control panel blew. My advice to you - think about a different brand.
Nancy
Scottsdale, Arizona
3helpful
I keep getting comm error 242 when people are faxing to me
The "sender's" fax machine is attempting to RECEIVE a fax. This happens because they don't have the document fully inserted into the scanner before dialing. (According to HP's error code listing for "comm error 242" - http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=buu02549) This is not a problem of a bad connection. Bad line condition codes are 223, 224 and most of the codes starting with 23.
Panasonic Panafax UF-790 Fax did not complete logging into memory. Comm. Journal comm. 212 What do I do?
its a receiving error code means a computer was trying to fax you and it didnt connect properly
7helpful
2answers
HP 3050 Engine Comm error
I have a HP 3050 three in one and I keep getting a engine comm error
ERROR MESSAGES
nthemba- all the error codes you see indicates phone line condition or error at reciving fax's end. For more details you can refer to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&lc=en&dlc=en&cc=us&product=79477&rule=17804&lang=en
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
