Sharp MX-2300N Color Copier Logo
Frdric Busquet Posted on Jan 29, 2016
Maintenance required: code DK - Sharp MX-2300N Color Copier
Dave Bretherton
Level 1:
Habit-Forming:
Scholar:
  • Contributor 48 Answers
  • Posted on Feb 26, 2016
 Dave Bretherton
Contributor
Level 1:
Habit-Forming:
Scholar:
Answers
48
Questions
0
Helped
64568
Points
75
The code refers to the black drum reaching the end of its life. Sometimes you will also have a VK code that is displayed along with the DK code. This refers to the black developer life. Both drum & developer have a life of 100,000 copies which is why you tend to get both codes at the same time. The maintenance code should still allow the copier to photocopy & scan as normal, so if the copy quality is still OK then the machine should continue as usual & the codes are reset when the drum & developer are replaced.
If you have a problem printing to the copier from a PC when the maintenance codes are displayed then this can be rectified 2 ways. The 1st way is to have the parts replaced & the counters reset. The 2nd way is to turn off SNMP setting within the printer driver. If you open printers & devices & locate your printer. Right click on the printer & scroll down to printer properties half way down the list (not the properties at the bottom of the list). The third tab along the top should be Ports. Click this tab & this will show the port details of your printer. Click on configure port & this will open another box. At the bottom of the box to the left there is a tick box with SMNP enable. If the box has a tick in it, untick the box, click apply then close all the open windows. This allows the printer to print when the machine displays maintenance codes.
Hope this helps.
Dave.
3 Related Answers
Anonymous
  • 95 Answers
  • Posted on Apr 11, 2009
SOURCE: I am getting a message "maintenacne required code:dk"
DK means the black drum has reached its maintenance life - 50k copies. you need to buy an ARC26DU drum unit. The drum counter will need to be reset after its installed.
here is a starting point : http://electronics.pricegrabber.com/fax-copier-supplies/Sharp-ARC26DU-Developer-Toner-Drum-Cartridges/m12754437.html
Hope that helps.
Anonymous
  • 11 Answers
  • Posted on Jul 13, 2010
SOURCE: maintenance required: code dk
Ok so the DK code means that the Black drum counter has reached its limit
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code 07
Then you can select what you want to clear so the bk drum unit
Execute this yes then press the CA key the machine will restart and away you go
I also do advise that you service representative comes along at some point to check the machine it could need parts because if you stretch the life of parts your machine could become unreliable... But that is up to you.
Anonymous
  • 33 Answers
  • Posted on Jul 21, 2010
SOURCE: Maintenance Required Code DK
black drum needs replaced
Top Sharp Office Equipment & Supplies Experts
George Mclaughlin
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
