Kitchen Ranges Logo
c
cindy macdonald Posted on Apr 13, 2016
F31 error code - Kitchen Ranges
1 Related Answer
Anonymous
  • 15935 Answers
  • Posted on Sep 29, 2010
SOURCE: error code f31 flashing
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Turn on over and get F31.
Hello, Janice -
There are many ovens in use today. It will help to know the make and model of your oven. You can add that information by choosing Comment and typing in the make and model of your oven
If yours is a Kenmore brand oven, the F31 error code means that the oven temperature probe has shorted out or there is a shorted sensor probe harness connection.
Sources of information + repair instructions:
https://www.shopyourway.com/questions/1068107
and
https://www.shopyourway.com/questions/1036659
If your oven is a Frigidaire gas oven, then the F31 error code also means there is shorted oven temperature sensor probe or a shorted sensor circuit.
Source of information:
https://www.shopyourway.com/m/questions/1018474
I hope you have the owner's manual for your oven. The F31 error code will probably be described in the manual.
Best wishes.
What does F31 mean on Frigidaire stove?
Thank you for your inquiry, friend!
Based off what you have described your Frigidaire range is displaying an F31 error code and you would like to know what it means. An F31 error code means a shorted probe connection. This could be a possible problem with your sensor probe, control panel, or probe connector. I would recommend performing a reset on your range and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not correct your issue you may need to seek help from a professional technician for proper diagnosis and repair. Best of luck! -Matt
/lfgf3014lbcwhat does f31 mean
Hello Jim, thanks for your post!
From my understanding your Frigidaire range, LFGF3014LBC, is displaying an error code of "F31". The "F31" error code stands for a shorted probe connection which could be an issue with your EOC (Electronic Oven Control), wiring harness, or RTD (Resistance Temperature Detector). I would suggest performing a reset on your range to help clear out any false error codes. You can reset your range by flipping off the household circuit breaker for ten minutes. I hope this information is helpful to some degree. -Matt
What does f31 error mean on fregidare gas range
Good Morning friend, thank you for your inquiry!
From what you have described your Frigidaire range is displaying an "F31" error code. An "F31" stands for a shorted probe connection. This could be an issue with your RTD (Resistance Temperature Detector), EOC (Electronic Oven Control), or wiring harness. I would recommend performing a reset on your range to help clear out any false error codes. In order to reset your range you need to disconnect power from it for roughly ten minutes. If this does not help resolve your issue and you continue to receive the error code you may need to have a professional out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
Kenmore elte oasis electric dryer error code f31
f31 code is a thermistor problem ,if you need help go to www.appliancerepairservice.com
1helpful
Kenmore model 790.7851 gives an F31 error code this is
hello,
The F31 is an error code indicating that water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
what you have to do to fix up this is to unscrew (open)ranger then trace the wire down to the reader sensor/panel clean all form of water and dirt around them after all this make sure that all wire are in there position mostly on the panel then couple it back as it was with this the problem of F31 is solve please do this with care
thank you.
2helpful
What is code F31
The F31 error code signifies that the heat sink in your washer got too hot. The motor control unit (MCU) stops the motor and sends the error the the central control unit (CCU) and the CCU resets the MCU. After this happens 4 times the F31 code will show.
It could be an electrical issue in either the MCU or CCU. Many times simply unplugging the unit will fix the problem. Otherwise, service must be called for.
A&E Factory Service is a nationwide servicer. Their telephone number is 1-800-905-9505
3helpful
I have a professional series frigidaire stove and it keeps showing an error code of F30. What does this mean?
Hi here is the meaning of the F30 error code. If you have any other questions please feel free to comment. Mike
F30
F31
Open probe connection.
Shorted Probe connection.
1. (F30 or F31) Check resistance at room temperature & compare to *RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace *RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
Top Kitchen Ranges Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
