Microwave Ovens Logo
Dixie Baxter Posted on Mar 13, 2018
Can you freeze Mashed Potatoes? - Microwave Ovens
1 Related Answer
Anonymous
  • 10865 Answers
  • Posted on Jun 02, 2011
SOURCE: I want to keep mashed
Hello mbr.... You do not need extra liquid unless you will be keeping them warm for more than 3 hours. IF that is the case, do stir them up at the end of the three hours and check to see if they are drying out. Keeping the lid on is key. Joe
How do I freeze cooked sweet potatoes with the peeling on them
Hello, Debbie -
Read the information here:
https://www.stilltasty.com/fooditems/index/18450
How did I find the web page? Easy.
Using my favorite search engine, Google, I entered the following search phrase, using quotation marks as shown:
freezing "cooked sweet potatoes"
You may wish to try the search strategy with your favorite search engine to determine what comes up for you.
Best wishes.
How to heat cooked potatoes for mashed potatoes
hi Judy.
Put in the large pot as you peel and slice so they don't turn brown. Be sure water covers the potatoes by 2 inches, on medium-high heat and bring to a boil. Reduce to medium-low heat, cook the potatoes for 20 minutes until the potatoes are soft and fork tender. Turn off the heat, and drain well in a colander.24 Nov 2015
Make Ahead Mashed Potatoes Reheated 5 Ways - Delicious Table
https://www.delicioustable.com/make-ahead-mashed-potatoes-reheated-5-ways/
if you want to know more go to this link.
How to heat cooked potatoes for mashed potatoes Google Search
How can I make cauliflower mashed more like mashed potatoes without them being runny?
The m.w. ovens wasn't created for mashed cauliflower...Try a steam boil and a blender.
Can you freeze raw potatoes and how do you do this?
i assume you want to pre-prepare chips for big family gathering? or for any period of time.
you need good freezing unit
potatoes
chips cutter
knife
3ltr (1 gallon) water with bit of salt and bit of vinegar in it
5kg (11lb) potatoes
table spoon
method:
water solution: to 3ltr (1 gallon) of water add and solve about 6 table spoon of salt and about same amount (6 table spoons) of vinegar (this solution will prevent blackening of the potato cuts), i am adding as well about 3 spoon of sugar to the solution, it allow liquid to cling better to the surface of potatoes, water should be cold, even few ice cubes in it will help
1. wash well your potatoes from debris, sand and whatever junk, remove unsightly, damaged or rotting bits from the potatoes
2. if you have chip machine or slicer - use it! chips should be not thicker than 12mm (1/2"), try not make them thinner than 3mm (1/8"), i do not bother with skinning them, but you may if you have masochistic tendencies. you can do that with knife as well, but will take longer. chips can be cut as straws, plates, sticks. waffle or whatever pattern you have in mind
3. chopped chips drop into the water solution and frequently stir as to allow all surfaces to be covered and prevent browning/blackening of the surfaces (this is oxidation of the surface, it is not poisonous but looks ugly)
4. after all potatoes were used, strain them from water, shake excess water and spread single layer on greaseproof (baking) paper or any other non-stick surface
5. your produce now need to be transferred to the deep freezer and frozen, minimum temperature should be -18c (0f), preffered will be -32c (-25f), if you are living in climate where these temperatures are outside, just put them outside...
6. after deep frozen (about 6h to 12h) divide them and pack them in sealed bags, in suitable portions
that way prepared chips can be stored for months, and if at lower temperature, even for years.
to fry:
have suitable fat at temperature of about 185c (365f), or whatever settings on your fryer is, you do not need defrost them, just directly from the fridge to the fryer, from the moment when they float, about 2min or until golden brown
enjoy!
if you like the recipy - why not vote for it?
How do I freeze cooked mashed potatoes?
Place them in a plastic container, close it, label and let go. I've never tried freezing mashed potatoes so can't testify as to how it holds up. But this is basically how I freeze everything else that comes my way.
2answers
While baking a sweet potato, the potato exploded and caught on fire. The microwave no longer works.a fire bro
I haven't heard of such a thing. You must have cooked it until there was no moisture left in the potato. That would also account for the failure of the oven. It would be the same as no load in the oven.
A thermal protect part is your current problem.
I want to keep mashed potatoes warm. Do I need extra liquid? I have an all-clad slow cooker, Model AC 65EB. The potatoes are hot and I want to keep them warm for a graduation party today.
We have a new 24"Dacor
The service manual is here and the parts list is here.
That mesh is the door screen which prevents microwave leakage.
It must be intact or replaced, or a fire hazard exists.
You can order Dacor parts by part number from the Pros here.
Top Microwave Ovens Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
