Contributor
- Posted on Aug 01, 2025
Re: Massage machine Osaki 7075R light on but not work,...
If your Osaki 7075R massage chair has the power light on but it's not running, that usually means something inside isn't working properly-even though it's getting power.
Here are a few things you can try:
- Unplug it for about 5 minutes and then plug it back in. This sometimes resets the system.
- Check the remote control-it might not be sending the signal to start, especially if a button is stuck or the screen isn't responding.
- Look for a blown fuse or tripped circuit inside the chair. These can stop the motor from running even if the lights still come on.
- Listen for any soft humming-if you hear that but the chair isn't moving, the motor might be jammed or damaged.
- If nothing helps, it's best to reach out to Osaki support or a technician. It could be a loose wire, motor issue, or something that needs professional repair.
