HP Pavilion dv6000z Notebook Logo
Posted on Sep 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot tap touch pad - HP Pavilion dv6000z Notebook
Anonymous
Level 3:
President:
  • Master 2,600 Answers
  • Posted on Sep 12, 2009
Anonymous
Master
Level 3:
President:
Answers
2600
Questions
0
Helped
1032218
Points
8362
There is not a whole lot of information that you are giving us. There would be two reasons the touchpad does not work...one, there is a small button above the touchpad and if it is red (orange) the pad is off and you have to tap that button until the light turns blue. If the light is blue, then the tapping part of the pad has been turned off in mouse properties. Open control panel > mouse Properties > device settings > click on settings button and enable tapping. All other touchpad settings are in there to modify also.
  • SoniaIP Sep 08, 2010
    Guru, I am having similar problems. I accidentally disabled my touchpad on my dv6000 and cannot go to the tab Buttons Pointers Pointer Options Wheel Hardwared Device Settings to allow me to follow the instructions you gave parrotheadpc above. I work from home and I am desperate, it just happened and need to work. PLEASE PLEASE HELP ME. I tried tapping on the picture which is in blue like you said above and nothing. Sonia 09/08/10
How do I fix my acer aspire touch pad?
some touch pads have a tap to turn off, and a double tap to turn back on... also check you F keys.
How to turn the touchpad on and of?
IF IT IS A NEW HP LAPTOP LOOK FOR A BUMP IN THE LEFT SIDE TOP CORNER OF TOUCH PAD ( MOUSE PAD ) DOUBLE TAP ON THAT AREA THEN U WILL NOTICE A LED LIGHT GLOWING NEAR TO THAT...THEN TOUCH PAD IS DISABLED,DOUBLE TAP ON THAT BUMP TO ENABLE TOUCH PAD
My touchpad is working only as a mouse, the tapping is not working..why is that ? I have an aspire 3680 mouse work and the 2 click buttons too only tapping is not working. I have check all drivers and they...
1. Go to control panel
2. open mouse options
3. click the device settings tab and you should see your touch pad as one of the devices.
4. Make sure your touch pad is highlighted and click the settings button
5. one of the options is tapping, and you can enable it here
That should get your mouse to click on touch pad taps.
Good Luck!
John Vickers
2helpful
Hi, I am using HTC touch P3450 model.Suddenly touch screen is not responding.So I gave a hard reset for factory restore settings.After loading the OS its asking to TAP the screen,but my touch is not...
Your touch pad need to be replaced. I had the same problem and order a complete face lift which includes the touch pad from ebay. It was included aslo the special tools needed to remove the screws. There many videos showing how to desasemble the phone in youtube, just search with your model and you will find videos showing all the dtails how.
Please not that the problem is with touch pad which is the one you touch directly on it, is only vinil cover and is working as a keyboard. Under touch pad is located the lcd display of the phone which other part .
Touchpad works but you cant tap
you might have like tap to click turned off. I know that can happen because on my old Toshiba Satellite m115 it happened a few times
Mouse touch-pad
Click Start > Control Panel > Mouse > Device Settings (tab) > Settings (right hand side, immediately under the white box with your touch pad device listed)
Select "Tapping" on the left and make sure it is enabled.
If tapping was enabled, go to "Sensitivity" on the left and adjust the touch settings.
Thanks for using the FixYa forums!
1helpful
Toshiba touch pad not working to tap of finger
First got to Start/Settings/Control Panel/Mouse(or there may be a separate Touch Pad setup) and check were options for touchpad Settings Options are tabbed or listed.
All touchpads allow on/off settings for Tap or NoTap. Also, check Sensitivity Settings. If very low, then Tap would have to be very hard to be recognized.
Next, reboot your computer.
112helpful
2answers
Synaptics touch pad, double tap not working
look in the sys tray, (lower left of screen) one of the icons will be concerned with the touch pad. you can turn on and of the double tap here. Sounds like yours is switched off.
Touch pad not working
That's a sign that the synaptic touch pad needs to be replaced. Eventually they wear out.
2answers
Touch pad freezes
reinstall your os, install best antivirus of today. it is the problem of your os and virus if its continues then problem with your hardware (cpu fan).
Top HP Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
