First you press the browse button, it's the round button in between the arrows, right above the number 2 keypad. Then you look for the picture of a screwdriver and wrench, press the right dot above the power key to select. Once it's selected, go down to the 6th row and select using the right dot. Then go down to the 6th row again which is the language option select it with the right dot. The search for English to change your language. That's it! Hope this helps! =)
First go to menu then setting,iniatial set up,then language.....pl rate me thanks....
