Microsoft Xbox 360 Console Logo
Posted on Oct 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix e73 error code for xbox 360 - Microsoft Xbox 360 Console
Anonymous
Level 2:
Novelist:
  • Expert 168 Answers
  • Posted on Oct 10, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
168
Questions
0
Helped
46149
Points
249
I personally have fixed most e73 errors by replacing the xclamps, re heating all the solder on the mainboard and replacing the heatsink paste with new.
e73 errors when searched for on the net say its something to do with the ethernet port BUT ive found it to be the lead free solder on the mainboard around the ethernet port which is at fault not the port itself.
you need to search the net for 3rrod fix and you need to do this yourself or take it to a repair center if your unsure how to do it.
out of 50 e73 errors ive fixed around 49 doing what i mentioned above.
run a search for 3rrod guides on the net or youtube.
if you get stuck email me
Linda
xboxrepairkit
5 Related Answers
Anonymous
  • 97 Answers
  • Posted on Jul 31, 2008
SOURCE: error E73
it looks like your ethernet port is fried...try disconnecting your cable to it and see if it boots....if it does your going to have to go wireless, it uses usb. good luck!
Anonymous
  • 33 Answers
  • Posted on Nov 16, 2008
SOURCE: E73 error or 1021 error code
here is what the error code means
E73: General Hardware Failure: Ethernet port... this error is caused by a problem with the Ethernet port.
and cose 1021 is a ghost code they have no idea from what i have found out
Anonymous
  • 378 Answers
  • Posted on Jan 12, 2009
SOURCE: xbox 360 error code e73
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
Anonymous
  • 68 Answers
  • Posted on Mar 31, 2009
SOURCE: sysem error E73 on Xbox 360
Follow the steps below, Hope this helps
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Remove the hard drive, turn on your xbox 360 without the hard drive.
3. Re attach the hard drive and turn on your xbox 360
4. If the steps wont resolve the issue, your console needs to be serviced. Contact Xbox Customer Support to check the warranty status of your xbox 360.. Good Luck!
Anonymous
  • 152 Answers
  • Posted on May 27, 2009
SOURCE: xbox 360 doesnt work because of one red light and message of E73 that they dont know how to fix
E73: I/O Hardware Error - Couldn't calibrate HSIO Bus from edram: this error is likely caused by a problem with the Ethernet port or supporting control devices.
You can try to find some parts online, but it looks like your Ethernet port is bad...
One red light and a e73 error code??
Hello sir
I have an error code E73...what can I do?
the problem is
2answers
My son's XBOX 360 got one RROD,error code E73
This may help. Good Luck and if it doesn't work after trying the link then you'll have to contact Microsoft customer support.
2answers
Xbox360 E73 proplem
this microsoft xbox 360 problem will be easily solved by our own , you dont want to get your xbox to the repair shop, use repair guide and fix your problem.
click here to download repair guide.
E73
http://www.xbox-360-red-lights.com/solving-xbox-e73-error
Got the Xbox 360 E73 error? Want to get it fixed? Fact is that this problem may be tough to fix, and that's why many people will tell you to send your console over to Microsoft and pay $150. But is it really worth your $150? Is there maybe another way to get it fixed? The Xbox 360 E73 error may be tough to fix, but this doesn't mean that you can't repair it by yourself.
3 ways to fix the Xbox 360 E73 error
1. Restart your console.
2. Unplug all AV cables, and also unplug the power cord from the wall socket. Once that's done, plug them all back in correctly, and put your console back on.
3. Take out the hard drive, and put your console on. If the troubleshooting error has been gone, put your console off, and get the hard drive in again. Than put your console back on.
If these tips didn't fix your Xbox 360 E73 error, you will have to open up your console, and fix the problem from within. You can do this by 2 ways. You either send it over to Microsoft, or you will actually repair the troubleshooter by yourself with a repair guide.
Fix Xbox 360 E73 error by Microsoft or by myself?
So what to choose? Well, if you send your console over to Microsoft, you will have to pay $150 if your warranty has been expired. Also, you will have to wait for 2-6 weeks before you can get back to playing. You'd better want to avoid this... Right?
It can be done way faster and cheaper... If you fix the Xbox 360 E73 problem by yourself, you will be able to get the problem fixed without spending $150. But, you will have to spend a little money on a repair guide, because that's what you will use.
You will use a repair guide, because it gives you step by step instructions that's including photo's and videos, so you will be able to open up your console, and fix the Xbox 360 E73 error very cheap and easily. See it for yourself, visit: Xbox 360 Repairs
Also, when you fix the Xbox 360 E73 error by yourself, you will be able to get it repaired in less than 1 day, or even within 1 hour. It's done before, so why wouldn't you be able to do it either? Want to play your favourite games again, today? Get yourself a repair guide, visit: Fix E73 Error
One red light on elite
Extended MS does not cover E73, so they won't fix for free :-(
The E73 error though is the NIC error (network), so usually shows a problem with the internet connection port, but can also be a problem with the motherboard. I have fixed the E73 issue in x360 units before, but that tends to be an error that's a real pain to sort.
Even once fixed, it usually comes back, it's really unlike any other E code error in that respect. Your cheapest option is just to get an HDMI white base unit on eBay (with no cables or anything) then just swap the white case for your black one, then sell yours on for spare parts.
Hope this helps.
1helpful
2answers
E73 error code. X-box is not connected to internet. Ethernet?
This is caused by overheating, a cold solder joint under the southbridge or ethernet chip.
Go here to find out more and how to fix it.
E73 error can you tell me how i can fix this problem myself thanks for your time..
It can be done way faster and cheaper... If you fix the Xbox 360 E73 error by yourself, you will be able to get the problem fixed without spending $150. But, you will have to spend a little money on a repair guide, because that's what you will use.
You will use a repair guide, because it gives you step by step instructions that's including photo's and videos, so you will be able to open up your console, and fix the Xbox 360 E73 error very cheap and easily. See it for yourself, Xbox 360 Repair Guide
Also, when you fix the Xbox 360 E73 error by yourself, you will be able to get it repaired in less than 1 day, or even within 1 hour. It's done before, so why wouldn't you be able to do it either? Want to play your favourite games again, today? Get yourself a repair guide, visit: Fix Xbox 360 E73 Error
2answers
Xbox 360 doesnt work because of one red light and message of E73 that they dont know how to fix
not sure if this will help but i found this video showing a fix for that problem
http://www.youtube.com/watch?v=GTBH29CmFHA
there are many more videos there also, good luck to you in fixing your xbox!
1helpful
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Narseman
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
