OKI B4600 Printer Logo
Anonymous Posted on Oct 30, 2009
What is error code 106 - OKI B4600 Printer
How To Fix Roblox Error Code 106?
Some Roblox players report that every time they try to join a friend, they get the error code 106. The error is reported on Xbox One and usually occurs for people who first try to join an online session. Read blog for solution
B430dn zeigt den Fehler: 106 Fatal Error 3819, was heiß das?
Error code 106 is Engine Control Error. Try replacing the engine control pcb.
Fisher Paykel Smartdrive MW058K error code 106
106. (01101010) Display Module to Motor Control Module Communications Error
These faults are reported when the Display Module detects an error in the communications
between the Display Module and the Motor Control Module.
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
What is code 89?
81. - 95. (0101xxxx) Phase 2 to 3 - Display/ Motor Controller.
See fault code 106
104. (01101000) Phase 2 to 6 See fault code 106
106. (01101010) Phase 2 to 3 - Display to Motor Controller module
Communications Errors (Phase 6 IW also)
These faults are reported when the Display module detects an error in the
communications between the Display module and the Motor Controller module.
Primary Source: Display module.
Action:
Replace Display module.
Secondary Source: Motor Controller module.
Action:
Replace Motor Controller module. If the new Motor Controller module corrects the fault, refit the original Display module.
1helpful
Fix code 104
104. (01101000) See Fault Code 106
1helpful
Error code 106, how to correct?
have you try to reinstall the software ??
You do it in this way, uninstall the software, reboot the computer and then reinstall the software.
If it still not work then return here :O)
have a nice day
please rate my answer
ERROR CODE 106
restore your system to previous date where its working fine then check
Installing error code -106
I suggest go to Start/Settings/Control Panel/Add remove programs.
Check and see if the program is in list and remove it. While in control panel go to system/Device Drivers check non have a yellow mark on them if so reinstall drivers or upgrade Reboot and try again.
Top OKI Office Equipment & Supplies Experts
George Mclaughlin
Grand Canyon Tech
Grand Canyon Tech
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
