Zoom X6 Adsl Wireless Gateway Rohs Router Logo
Anonymous Posted on Nov 02, 2009
Where would i find my wireless key code so i can use wireless
Samyfam
Level 3:
  • Master 379 Answers
  • Posted on Nov 02, 2009
Samyfam
Master
Level 3:
Answers
379
Questions
Helped
210596
Points
1167
The wireless key is whatever you want it to be, within the charater range A-Z, 0-9, and normally up to 64 charaters long.
You enter your chosen key under the configuartion settings of your wireless router, then enter the exact same key in to the PC which you want to connect wirelessly. Exactly how you do this depends on how your PC is managing it's wireless connections. In the majority of cases, it will be your Operating System (e.g. Windows) which, if your wireless adapter is enabled, will detect your wireless router shortly after boot-up and offer you the option to connect. This is when you enter the same key you set on your router.
Your router handbook should show you how to change its configuartion settings, as would your PC handbook.
If you dont have these, and it all sounds a bit complicated, can you ask an IT savvy friend to help ?
Testimonial: "hi yes very helpful thanks chris "
How can i find out my encription code for my asus eeepc
The encryption code is in your router's wireless setup.
To connect your computer to a wireless router, you click the Refresh network list, then Choose your wireless network and then click Connect to your secured Wireless Network, it will asks for a Network Key before allowing you to connect into your wireless network. This Network Key is either the WEP, or WPA or WPA2 Encryption key that is configured in the Wireless settings in the Router. The Passphrase is an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrase or WPA or WPA2 key that was used to configure the Encryption key in the wireless router. http://www.fixya.com/support/r5270415-network_password_network_address For information on securing your wireless network, configuring the wireless router and configuring the wireless card in the laptop/computer, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Forgot security code
Are you speaking about wireless network security code?
You will need to open the setup page of the router and check the wireless settings of the router.
On the setup page you will find the wireless network key.
See How to find wireless network key
Hi do you know how I can connect my lap top to the internet wireless with my linksys wireless router ? the lap top asks for an access code and I do not know what it is or how to find it do you know how to...
The access code or password is the encryption key in your wireless router, without this key the wireless router won't allow the laptop/computer to connect to this wireless router.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer/laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
I am trying to connect my laptop to wireless internet, but it keeps asking for the security key. What is it?
an access key is configured in the wireless routers web console to allow only the users with the key to connect to it. sometimes referred to as a "WEP KEY" or "WPA key" or "authentication code" To login to your web console, join your computer to your wireless router with a network cable (yellow below) to an Ethernet port 1,2,3 or 4 ef8efd2.jpg open your browser and surf to (instead of www) 192.168.1.1 or 192.168.0.1 (most common) you should presented with a login screen most common username and password is admin and admin a482702.jpgonce you have logged in look for your wireless security setup screen such as this.....5be26fc.jpg
look for the Wireless and Security Screens to enter or check your access security code, enter a code or review the existing one. Then once you save your changes you can connect with your laptop, now that you know the security key.6679972.jpg
Key code
the key code that the computer is the Network key, A network key is a password of a secured wireless network, if your the owner of the wireless router or access point you need to access the router to get the network key to be able to connect to the intennet
2answers
What is a wep key on psp
a wep key is the security code for ur wireless network, If you have never altered it then it would be the default code... normally this is found on the reverse or underside of the wireless router. There is no wep key actually on the psp.
If no wep key or wireless security key is found on the router, check with your internet service provider.
I have a wireless Canon printer but I can't set it up as it asks for a WEP code...what is that?
WEP code is a network security key which is configured in wireless router. Ask the person for the key who has configured the wireless router. Or if you have set any key in your laptop/computer for wireless LAN card, then you need to enter this key.
Must I have key code to install Netgear router
What key code are you referring to?
Is the code the encryption key?
The WPA2 or WPA or WEP encryption key is configured in the wireless settings of the Netgear wireless router.
This key is then used to configure the wireless card in the computer to allow access to the Netgear wireless and to prevent unauthorized access to your wireless router, network and Internet.
I want to share a laptop with my secure wireless. How do i get the key code?
Contact the manufacture of your wireless router for assistance in getting the key that is configured in your router/model.
2helpful
How do i find my network key code?
if you're pertaining about the wireless key code, all youneed to do is access the router's setup page by typing http://192.168.2.1 at the address bar of your browser. by default, admin is the username and password. now go to the wireless part of thr router and look for the wireless security key code.
hope this'll help you
ciao
Top Zoom Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
