20 Most Recent Zoom X6 Adsl Wireless Gateway Rohs Router Questions & Answers
Wireless phone connects and then drops.
I switched to a qwest modem and a lynksys router. Works flawlessly now.
3/11/2014 2:50:57 PM • Zoom X6 Adsl... • Answered on Mar 11, 2014
0answers
I have zoom on my home pc and now I would like to
you should try reset to factory settings, may be you should look behind your zoom device, there is small hole or something that have words "RESET". All password will be empty, but you should reconfigure for your zoom device
5/10/2011 9:25:17 AM • Zoom X6 Adsl... • Answered on May 10, 2011
Can i use my zoom x6 model 5590 adsl wireless
yes there is one way if you dont have a house phone. if you have a cellphone turn it on and put it on top of your machine.
1/3/2011 10:23:43 PM • Zoom X6 Adsl... • Answered on Jan 03, 2011
0answers
Hi how can i put
Be the first to answer 11/11/2010 10:15:28 PM • Zoom X6 Adsl... • Posted on Nov 11, 2010Be the first to answer
How do i open the
Try this:
To access the Zoom Configuration Manager (web-based configuration utility) on the Zoom DSL modem:
  1. Close any open programs including antivirus and pop-up blockers.
  2. Open a web browser, and in its address bar, type http://10.0.0.2 (or http://192.168.0.1 for Zoom ADSL X6v users) and then press Enter (or Return).
  3. In the Enter Network Password dialog box, type the following username and password in lowercase then click OK. (Note: The modem User Name and Password you enter here are NOT the same as the User Name and Password that your Internet service provider may have given you.)
    • User Name: admin
    • Password: zoomadsl (where "l" is a lowercase letter L)
If you are not prompted for a User Name and Password, click here for more information.
11/2/2010 10:43:51 PM • Zoom X6 Adsl... • Answered on Nov 02, 2010
2answers
PPP Password doesn't match error
1. You should better check the power supply if it is plug on, properly on a 220AC Voltage. 2. After installing your disk suppose to be you should reset the configuration of your DSL 2740B so that it will restore back to the main configuration of the system. (to reset your DSL 2740B try to look for a small button on it. then press according to standards then your done. Good luck and i hope this steps will help you accurately. God Bless.
10/9/2010 11:54:57 AM • Zoom X6 Adsl... • Answered on Oct 09, 2010
Hi, I set up my
Simply re-set the Router, and login as default user, and set it up again, as there is NO WAY to recover these passwords, unless you remember them :(
http://www.zoomtel.com/techsupport/adsl/adsl_5590cf.shtml
Above is your manual download link, it is all explained in there.
8/4/2010 8:51:24 AM • Zoom X6 Adsl... • Answered on Aug 04, 2010
I have a Zoom 6 router and Windows VISTA.
Provide more detail information for further assistance.
1.2nd device = wireless or hard connect??
2.Model numbers of each device?
3.Browser used? Explorer or Firefox etc.?
4. Laptop or Desktop??
5/17/2010 2:21:57 AM • Zoom X6 Adsl... • Answered on May 17, 2010
Log on problems
trought and email client? or trought the website?
if its trought the website it's the browse that it's not saving cookies try to go to the internet options and select the option to allow cookies or you can always download a new browser ;) if its trought an email client let me know.
4/27/2010 7:22:47 PM • Zoom X6 Adsl... • Answered on Apr 27, 2010
The unit looses internet connection
Generally this is a common sympton of any brand of wifi router over about a year or so old. The wifi section is in the process of failing. It will loose the connection more and more and then the wifi portion of the router will no longer work. I have a pile of various brands that displayed these symptoms before they stopped working.
What you need to do is replace the router. We have had better results with D-Link and NetGear wifi routers. Linksys seems to be the worst one right now. This is unfortunetly a common failure in non-commercial grade wifi routers. So the best advice is to check for a sale on the dlink or netgear and replace it. It will save you a lot of headache and frustration.
4/13/2010 10:14:33 PM • Zoom X6 Adsl... • Answered on Apr 13, 2010
UNABLE TO CONNECT IPOD TOUCH TO MY COMPUTOR
the computer may have some problems reading the driver for your iPod
3/9/2010 1:59:49 AM • Zoom X6 Adsl... • Answered on Mar 09, 2010
5answers
I have a wireless network
Well, you need to scan for the wireless network and enter the correct WEP key on your Roku. Please disable MAC address filtering on the ZOOM router and check if you can connect to wireless network on ROKU.
Let me know if you need any further help.
3/7/2010 11:49:00 PM • Zoom X6 Adsl... • Answered on Mar 07, 2010
IPOD Touch asks for password; password unknown
To configure your router, open your web browser. Type the default IP address (http://10.0.0.2) into the Location field of your browser and press the Enter key. A Login screen will appear. Use the below to log into your router.
The default user name is admin
The default password is zoomadsl
You click on the icon labeled Wireless at the top of the screen.
Set the Wireless status drop down menu to Enable
The SSID will be set to zoom by default. You probably want to change that since everybody will know this type of network.
You can Hide the SSID if you would like by choosing True on the Hide SSID option. This will make it harder for people to know how to connect to your network. Just remember that you will not be able to see this as well.
Under the Encryption you will need to pick your Encryption type. If you pick WEP-64 bit then you will want to click the Passphrase box and place your passphrase and have it generate a random key. If the Default Key is set to 1 then you would use the Key1 key. Make sure you click on the Save Changes so that it keeps these setting.s
Hope that helps!
1/8/2010 8:36:16 PM • Zoom X6 Adsl... • Answered on Jan 08, 2010
I cannot get my zoom 6 router to work with windows
If you are trying to connect to the wireless network, then first you should know all the wireless settings of the router ( SSID , Security key or password).
If you don't the wireless settings of the router , then you will need to access the router set up interface.
On the set up page of the router you will be able to find the wireless settings of the router.
Once you have the wireless settings of the router then you just need to connect to the wireless network on your computer.
WINDOWS VISTA/ Windows 7
In case of windows You will find 2 computer icon in the bottom right hand corner.Right click on it and go to the option " Network and Sharing center ". Once you open the network and sharing center you will find the option " connect to the network " in the top left hand side. Click On connect to the network and you will see the wireless network that you want to connect. If it secured network then type the network key or passphrase and you will be able to connect.
If you get the message " additional log on information required " then you will need to add the wireless network manually.
If you get the message " settings saved on this computer do not match ..." then you will need to remove the network from the preferred network list. Try to connect again.
If you get the message " Press the configuration button ..." , On the same window at the bottom you will find the option " I want to enter the key manually " or " I don't want to configure the network ..." Click On it and it will ask you for the key.
If you see " Enter PIN number " , then at the bottom you will find the option " I want to enter the key manually " or " I don't want to configure the network ..." Click On it and it will ask you for the key.
Click Here for more info
12/22/2009 6:01:35 PM • Zoom X6 Adsl... • Answered on Dec 22, 2009
How do I put a password in place?
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
12/18/2009 12:47:50 PM • Zoom X6 Adsl... • Answered on Dec 18, 2009
Where would i find my wireless key code so i can
The wireless key is whatever you want it to be, within the charater range A-Z, 0-9, and normally up to 64 charaters long.
You enter your chosen key under the configuartion settings of your wireless router, then enter the exact same key in to the PC which you want to connect wirelessly. Exactly how you do this depends on how your PC is managing it's wireless connections. In the majority of cases, it will be your Operating System (e.g. Windows) which, if your wireless adapter is enabled, will detect your wireless router shortly after boot-up and offer you the option to connect. This is when you enter the same key you set on your router.
Your router handbook should show you how to change its configuartion settings, as would your PC handbook.
If you dont have these, and it all sounds a bit complicated, can you ask an IT savvy friend to help ?
11/2/2009 12:31:21 PM • Zoom X6 Adsl... • Answered on Nov 02, 2009
Zoom resets using yahoo messenger
http://portforward.com/english/routers/port_forwarding/Zoom/X6/Yahoo_Messenger_Chat.htm
8/20/2009 8:12:57 AM • Zoom X6 Adsl... • Answered on Aug 20, 2009
How do i conet to all my game cosoles
You need to purchase some "Ethernet Cords", these come in different categories of quality, ranging in price. Because of your router I would recommend that you purchase Category 5E also known as Cat 5E.
Before you purchase this cable though, you want to measure out how long you need each cable, to ensure you purchase enough to get the job done, and as well as allowing slack in the cable for instance if you want to hide the cables in the ceiling to make it look nicer, allow about 5 ft more then you think it will need. You can purchase Category 5E cables online here.
Another possible solution for you to connect to all of your game consoles would be purchasing separate wireless adapters per device, but that method isn't as cost friendly. For instance, the wireless adapter for the Xbox 360 is $99.99 from Microsoft here.
If this did not solve your problem, please leave a comment and I'll get back to it as soon as I can =)
8/12/2009 10:46:05 PM • Zoom X6 Adsl... • Answered on Aug 12, 2009
Zoom X6 Adsl Wireless Gateway Rohs Router Logo
Popular Tags
49 questions posted
Top Zoom Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Zoom Computers & Internet
Most Popular Question
open
  • Computers & Internet
