Zoom X6 Adsl Wireless Gateway Rohs Router Logo
Posted on Nov 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i open the config manager - Zoom X6 Adsl Wireless Gateway Rohs Router
Level 3:
  • Zoom Master 7,733 Answers
  • Posted on Nov 02, 2010
Zoom Master
Level 3:
Answers
7733
Questions
0
Helped
1899777
Points
21487
Try this:
To access the Zoom Configuration Manager (web-based configuration utility) on the Zoom DSL modem:
  1. Close any open programs including antivirus and pop-up blockers.
  2. Open a web browser, and in its address bar, type http://10.0.0.2 (or http://192.168.0.1 for Zoom ADSL X6v users) and then press Enter (or Return).
  3. In the Enter Network Password dialog box, type the following username and password in lowercase then click OK. (Note: The modem User Name and Password you enter here are NOT the same as the User Name and Password that your Internet service provider may have given you.)
    • User Name: admin
    • Password: zoomadsl (where "l" is a lowercase letter L)
If you are not prompted for a User Name and Password, click here for more information.
1helpful
How to remove acer ecolo management pop up?
in xp
type msconfig in run box
you will get ms config in start up tab check for your pop up app in list and un check
also search in services tab but below list check the hide microsoft services
and apply go
in windows 7 :
start up is in task manager
open task manager go to start up tab right click on app and disable it
but services is is msconfig
How to config to work wireless
bridge irb
interface Dot11Radio0
no ip address
broadcast-key vlan 1 change 45
encryption vlan 1 mode ciphers tkip
ssid cisco
vlan 1
authentication open
wpa-psk ascii 0 cisco123
authentication key-management wpa
ssid ciscowep
vlan 2
authentication open
ssid ciscowpa
vlan 3
authentication open
Step 5 bridge-group number
Example:
Router(config-subif)# bridge-group 1
Assigns a bridge group to the subinterface.
Note When the bridge-group command is
enabled, the following commands are
automatically enabled, and cannot be
disabled. If you disable these commands
you may experience an interruption in
wireless device communication.
bridge-group 1
subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1
block-unknown-source
I tried to restore my t5082 with the restore disk, now im caught in a loop that goes to the boot screen only, i tried safe mode, and everything.. nothing works
First fix up cd/dvd to boot from
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
if still no luck
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone
Insert the Windows XP startup disk into the floppy disk drive or insert the Windows XP CD-ROM into the CD-ROM drive and then restart the computer
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so
When the "Welcome to Setup" screen appears, press R to start the Recovery Console. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
copy c:\windows\system32\config\system c:\windows\tmp\system.bak
copy c:\windows\system32\config\software c:\windows\tmp\software.bak
copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
copy c:\windows\system32\config\security c:\windows\tmp\security.bak
copy c:\windows\system32\config\default c:\windows\tmp\default.bak
delete c:\windows\system32\config\system
delete c:\windows\system32\config\software
delete c:\windows\system32\config\sam
delete c:\windows\system32\config\security
delete c:\windows\system32\config\default
copy c:\windows\repair\system c:\windows\system32\config\system
copy c:\windows\repair\software c:\windows\system32\config\software
copy c:\windows\repair\sam c:\windows\system32\config\sam
copy c:\windows\repair\security c:\windows\system32\config\security
copy c:\windows\repair\default c:\windows\system32\config\default
Type exit to quit Recovery Console.
Your computer will restart
hope it helps
1helpful
Wifi Signal Problem ???
You have the following options.
1. Move closer to the router
2. Purchase and install a wireless usb adapter that plugs into your usb port from Tiger Direct at: http://www.tigerdirect.com
3. Try using another client to manage your wireless. Usually there are 2 ways to manage your wireless on the laptop. You can use the software that came with your internal wireless card or you can use Windows (zero config) to manage your wireless. Which ever one you are now using, switch to the other. Open the software that controls your wireless and look through the tabs searching for where it will say something like "Let this tool Manage the Wireless" or "Let Windows Zero Config Manage the Wireless". Which ever one it is using switch to the other by checking or unchecking the box. Most times one will produce a better and stronger signal than the other.
Can not connect because password is to long
There are two ways to connect using wifi. One way is to let the sofware that came with the adapter (in your case Centurylink) or you can let windows manage the wireless (Called Windows Zero Config). Open your Century Link software and look around through it at all the tabs and if you see something like Let this too manage the wireless connection, uncheck it. If you see something like Let Windows Zero Config manage the wireless connection check it.
Windows will allow for a long password.
2answers
How do i reset my at-8000s switch to factory default by using command
follow this step
KIMIA# delete
startup-config Delete startup configuration (Reboot from defaults)
flash:// Delete a file from the flash (flash://filename)
WORD Specify name of file
KIMIA# delete startup-config
<cr>
Delete startup-config [y/n]? y
Startup file was deleted
KIMIA#
User Name:manager
Password:friend
console#
console#
2helpful
3answers
My windows xp doesn't even see that I have inserted a Kingston 16GB DataTraveler. Is there something in the system I must reconfigure?
Try to go via disk management and see.
To go to disk management follow the the step below..
  1. Open control panel.
  2. Open administrative tools.
  3. Select Computer Management.
  4. In the left column select disk management.
  5. It will populate all the disk and partition present.
Try to see if is present here , may need to format or create a partition.
Try this.
Cheers
2answers
Invalid operation 425: the printer cannot be accessed. It may be locked by another application.
Hello, Joyce.
If this is used by multiple users, be certain that others are logged out (and PCs shut off if necessary).
Also, from Epson Support: be certain to set to share the OPOS in SO Mgr config. This is under SO Mgr> File> Config> Options> POS Options> 'Share the OPOS printer with other applications'.
Hope this helps.
Dell Inspiron B130. Need to disable DELL Wirless WLAN Card Utility and use Windows for internet usage. Any thoughts?
open the Dell Wireless utility from the start menu, on the 1st page, uncheck the box That has the Dell utility manage the Wireless
Once that is unchecked, then you can manage the Wireless using the Windows Zero Config
Top Zoom Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
