Need a code for a kenwood cd player
You need a remote for the KDC-MP628 for this to work.
1)Press >>| and Auto keys simultaneously on the faceplate and hold
for 4 seconds.
2) The screen will
still say CODE, but the - - - - will disappear! When this happens press
the 5 key on the remote twice and it enters a K on the display on the
faceplate. Hit the >>| key on the faceplate.
3) Press the 2
key on the remote three times and it enters a C on the display on the
4) Press the 2
key on the remote once and it enters an A on the display on the
5) Press the 7
key on the remote twice and it enters an R on the display on the
6) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
Just call 1800kenwood
SOURCE: SECURITY CODE
hold auto and track up for 3 seconds. use remote to enter *KCAR* hold track up for 3 seconds, it will be accepted
SOURCE: Unlock code for my kenwood cd player
if its a kenwood try this :)
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
SOURCE: need unlock code for Kenwood kdc-x693 or need to
Kenwood KDC-X693 Car CD/ MP3 Player
keeps reading protect
I bought my truck with the CD Player already in it and I don't have my Manual for the player. It worked for a long time but here recently I had to change my alternator and when I got my truck back the CD feature on the player didn't work. I noticed that there are tw bars that have my CD locked in it. The radio still works but it won't play the CD of eject it. I figured it was a security feature that happed when the battery was unhooked. ANy help would be appreciated. Thanks.
Bucket_turner@hotmail.com
I am having the same problem I have tried almost 5000 different coders and have had no luck. Can you let e know if you hear anything ? Thanks Kent @ kent_kegley@yahoo.com
is there a reset code or way to reset the security code for a used kenwood kdc x579?
i have a kenwood kdc-ps809 i need a code for
need seceruity code kenwood kdc mp232
