SOURCE: Mouse is not responding at all
try checking your function key on your laptop and try pressing Fn and the key that corresponds to touchpad to unlock it..
SOURCE: i accidently disabled the scroll/wheel feature on touchpad/mouse for note book
go to control panel and look for the mouse icon. from there you can change the settings of your mouse to enable it.
SOURCE: hp dv7-1285dx touchpad vertical scroll no longer working
Whatever be the laptop, HP bundles the necessary drives in the C drive under the folder SwSetup. You'll find the touchpad driver in this folder. For the steps in installing and making the touch pad work follow
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00678194&cc=us&lc=en&dlc=en&product=3860674
SOURCE: vertical scroll not working on touchpad
The easiest way is to borrow a mouse and allow it to be discovered. This will give you the device tab in control panel. It should then work with your mouse.
SOURCE: touchpad is not responding and keyboard
Try shutting down the device and taking out the battery for 10ish seconds. Reinsert it, and power up your laptop. Sometimes this method takes 2 tries, but usually corrects the power/allotment conflicts keyboards and touchpads have with HP motherboards.
