Microsoft Xbox Console Logo
Posted on Feb 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E73 error - Microsoft Xbox Console
Anonymous
Level 2:
New Friend:
  • Expert 60 Answers
  • Posted on Feb 08, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
60
Questions
0
Helped
12308
Points
159
E73: I/O Hardware Error - Couldn't calibrate HSIO Bus from edram: this error is likely caused by a problem with the Ethernet port or supporting control devices
One red light and a e73 error code??
Hello sir
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
I have an error code E73...what can I do?
the problem is
E73
http://www.xbox-360-red-lights.com/solving-xbox-e73-error
Got the Xbox 360 E73 error? Want to get it fixed? Fact is that this problem may be tough to fix, and that's why many people will tell you to send your console over to Microsoft and pay $150. But is it really worth your $150? Is there maybe another way to get it fixed? The Xbox 360 E73 error may be tough to fix, but this doesn't mean that you can't repair it by yourself.
3 ways to fix the Xbox 360 E73 error
1. Restart your console.
2. Unplug all AV cables, and also unplug the power cord from the wall socket. Once that's done, plug them all back in correctly, and put your console back on.
3. Take out the hard drive, and put your console on. If the troubleshooting error has been gone, put your console off, and get the hard drive in again. Than put your console back on.
If these tips didn't fix your Xbox 360 E73 error, you will have to open up your console, and fix the problem from within. You can do this by 2 ways. You either send it over to Microsoft, or you will actually repair the troubleshooter by yourself with a repair guide.
Fix Xbox 360 E73 error by Microsoft or by myself?
So what to choose? Well, if you send your console over to Microsoft, you will have to pay $150 if your warranty has been expired. Also, you will have to wait for 2-6 weeks before you can get back to playing. You'd better want to avoid this... Right?
It can be done way faster and cheaper... If you fix the Xbox 360 E73 problem by yourself, you will be able to get the problem fixed without spending $150. But, you will have to spend a little money on a repair guide, because that's what you will use.
You will use a repair guide, because it gives you step by step instructions that's including photo's and videos, so you will be able to open up your console, and fix the Xbox 360 E73 error very cheap and easily. See it for yourself, visit: Xbox 360 Repairs
Also, when you fix the Xbox 360 E73 error by yourself, you will be able to get it repaired in less than 1 day, or even within 1 hour. It's done before, so why wouldn't you be able to do it either? Want to play your favourite games again, today? Get yourself a repair guide, visit: Fix E73 Error
Xbox 1 flashing red light and e73 system error
e73 is an input/output error. Hopefully you are still under warranty. Contact Microsoft at Toll free: (800) 4MY-XBOX or (800) 469-9269. If you are outside of your warranty period, I believe they will still repair it for $99
One red light on elite
Extended MS does not cover E73, so they won't fix for free :-(
The E73 error though is the NIC error (network), so usually shows a problem with the internet connection port, but can also be a problem with the motherboard. I have fixed the E73 issue in x360 units before, but that tends to be an error that's a real pain to sort.
Even once fixed, it usually comes back, it's really unlike any other E code error in that respect. Your cheapest option is just to get an HDMI white base unit on eBay (with no cables or anything) then just swap the white case for your black one, then sell yours on for spare parts.
Hope this helps.
My xbox 360 has shown up one red flashing light and E73
HI. This is an Ethernet port issue.
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port. Try using a new Ethernet cord. If the error continues after the new cord is used, contact Microsoft for a repair ticket. the port will need to be replaced. (Internal connection failure)
Possible solder break
E73 error can you tell me how i can fix this problem myself thanks for your time..
It can be done way faster and cheaper... If you fix the Xbox 360 E73 error by yourself, you will be able to get the problem fixed without spending $150. But, you will have to spend a little money on a repair guide, because that's what you will use.
You will use a repair guide, because it gives you step by step instructions that's including photo's and videos, so you will be able to open up your console, and fix the Xbox 360 E73 error very cheap and easily. See it for yourself, Xbox 360 Repair Guide
Also, when you fix the Xbox 360 E73 error by yourself, you will be able to get it repaired in less than 1 day, or even within 1 hour. It's done before, so why wouldn't you be able to do it either? Want to play your favourite games again, today? Get yourself a repair guide, visit: Fix Xbox 360 E73 Error
How to fix e73 error code for xbox 360
i personally have fixed most e73 errors by replacing the xclamps, re heating all the solder on the mainboard and replacing the heatsink paste with new.
e73 errors when searched for on the net say its something to do with the ethernet port BUT ive found it to be the lead free solder on the mainboard around the ethernet port which is at fault not the port itself.
you need to search the net for 3rrod fix and you need to do this yourself or take it to a repair center if your unsure how to do it.
out of 50 e73 errors ive fixed around 49 doing what i mentioned above.
run a search for 3rrod guides on the net or youtube.
if you get stuck email me
Linda
xboxrepairkit
I am getting Error E73 on my xbox 360 and need help
E73 usually means a problem with the ethernet port, or around that area.
We offer competitivley priced repairs and a 120day warranty.
FixMyConsole
1helpful
E73 error or 1021 error code
here is what the error code means
E73: General Hardware Failure: Ethernet port... this error is caused by a problem with the Ethernet port.
and cose 1021 is a ghost code they have no idea from what i have found out
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Narseman
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
