You will need a operating
system disk or a repair disk to fix it. Insert it in the drive then boot
from it. You want to get to a dos command prompt (black screen with white
lettering) and type the following commands. Press ENTER after each
command.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the dos
command prompt and run the check disk utility.
To
run the check disk utility you will need a repair disc or a operating system
disc. Put the disc in the cd drive and boot from it. You want to
get to the Dos Command Prompt (Black screen with white letters) and type the
following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the
percentages going from high to low, this is normal. Let it run to
completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.
Try doing a Repair Install that way you don't loose your data, documents,
music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when
the options appear.
In Vista and Windows 7 you want to get to the recovery
console and look down at the bottom of the window for the Dos Command.
command.
bootrec.exe /fixmbr
To
the options appear.
command.
bootrec.exe /fixmbr
To
the options appear.
