SOURCE: low/weak flame on Weber Genesis Silver B Grill.
hi my name is mark, could be one of two things the regulator on the propane tank try gently tapping on regulator it could be sticking, and make sure the vent on regulator does not have a spiders web . or the orifices to the burners are restricted. check regulator some are ajustable, some are not. hope that helps. thanks for your question.
SOURCE: replacing the crossover ignition system
What you're referring to is called a Collection Box. It traps gas so it will ignite. You can purchase a new one directly from Weber or from Appliance Factory Parts http://www.appliancefactoryparts.com/
Hope this helps you get the part you need. Happy Grilling!!
SOURCE: Weber Genesis outdoor grill. The ignitor clicks
If you hold down the igniter can you smell the gas coming out of the burners.
Have you disconnected the pipe from the barbie to see if the bottle regulator is actually letting gas through.
Turning the gas on in free air with no one smoking or naked fllames near the pipe is ok
You just crack open the valve a turn or two and you should hear and smell it.
If there is gas coming out og the pipe and not out of the burners then the gas control valve in the barbie is at fault and needs replacing
SOURCE: How to replace ignition switch
where does the ignitor switch plug into ? genesis ....came unpluged
