Computers & Internet Logo
Posted on Sep 15, 2010
Boot manager missing problem: - Computers & Internet
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
384
Points
I successfully formatted my Toshiba Satelite laptop using the original recovery disks. However, when I try to restore it using the recovery disks, the systems gives an error message of BOOT MANAGER IS MISSING. The system doesn't recognize the recovery disks and I can not install (reinstall) the Windows Vista on the mechine.
Please help me.
  • Anonymous Oct 26, 2010
    LAPTOP INFO: Toshiba Satellite L305D (MODEL # PSLC8U-03701Q)
1helpful
Bootmgr missing ctrl 7
try to boot from a live distro and to see the hd status in a program like GParted. eventually you can install a boot manager from there
How do I fix missing boot manager
There can be different causes for this problem:
If having reset the motherboard BIOS configuration, then check that the primary boot device is configured properly.
Haveing problems with hp notebook 1100 boot mgr missing error while initializing NIC
Hi There,
I'm having trouble understanding what you mean by this - are you attempting to boot from LAN? Are you able to boot into windows at all?
What it sounds like is that your computer is either missing a boot manager, or you've assigned (in the bios) LAN boot as the priority boot device.
If that's the case, you can change the boot device priority back to internal hard disk in your BIOS (pressing F2 or F10 at startup splash screen)
If you're missing a boot manager for a windows installation, you can insert your windows installation disk and select "repair an existing installation" to repair your boot manager
Says boot manager is missing
Try inserting the windows recovery disc and reboot the machine. At the language screen, bottom left, click repair your computer. At the recovery options screen, click on startup repair. This should recover the boot manager file. Reboot machine when completed.
Boot manager is missing
Hey Edward E. Hammett,
Thanks for being here with me.
Follow my tip here . i am sure you can do it. and if you succeed then review me.
Tip For Boot Manager Missing
Optional My Article Page just for Technocrats
Boot mgr is missing
Boot Manager is missing If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529 More Info MS KB 927391 Check points for fixing missing boot-manager: Check that your boot device is configured properly Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". Boot Manager is compressed If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart OR maybe try this first. Check points for fixing compressed boot-manager: Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files. If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands: compact /U C:\bootmgr compact /U C:\ntldr If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands: attrib -c c:\bootmgr attrib -c c:\ntldr
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
2helpful
2answers
Boot manager is missing how to solve
7helpful
3answers
you can often fix it right back up using the original Vista installation disk. Which comes with a pretty extensive System Recovery Tool that's got lots of options. Set your computer to boot from DVD (using the Boot setting in the BIOS), insert the disc and restart. Vista will prompt you for language and keyboard layout options, then ask if you want to reinstall Vista or repair your installation. You want Repair. From there Vista's System Recovery Tool will take over. this is the only way to get back from the dreaded boot manager missing error.
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
