Vacuums Logo
Posted on Nov 06, 2010
Need to know how to defrost on R200BW sharp microwave oven.
Anonymous
Level 1:
New Friend:
  • Contributor 34 Answers
  • Posted on Nov 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
34
Questions
0
Helped
12560
Points
60
I know this is NOT the exact manuel...after 2 hours i had not much luck. But i did see most sharp key pads are a like. I think this WILL work / help see page 16...the whole page. http://files.sharpusa.com/Downloads/ForHome/HomeAppliances/MicrowaveOvens/Manuals/mic_man_R820B.pdf Sharp is stingy...can buy the manuel here. http://www.sharp-cart.com/ecom/accessories.htm?action=getSearchItems&ss_id=1533&view=catalog/ss_items Every one elese is looking for a free fix also...lol Good luck
I have a kenmore elite microwave oven model 363 63692301 stoped heating food ;. fan & turntable work. HELP!
Hello, two things. The mega-tron tube is gone south, or the HV diode is open/shorted to ground which will cause to open. If the microwave meta-tron tube is bad then recyle your microwave oven and buy a new microwave oven. One can buy a new microwave oven cheaper than buying a microwave tube. GB...stewbison
Sep 12, 2011 • Vacuums
I NEED TO FIND AN OWNERS MANUAL TO R308NWW COUNTERTOP MICROWAVE.
Here is a direct link to the Owner's Manual for your Sharp microwave oven:
http://files.sharpusa.com/Downloads/ForHome/HomeAppliances/MicrowaveOvens/Manuals/mic_man_R307N_308N.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I hope that was helpful to you, good luck and take care.
Joe.
Aug 15, 2011 • Vacuums
Oven working microwave not
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Mar 18, 2011 • Vacuums
Clock and time work press start just clicks and nothing runs ge jet 342g microwave
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 16, 2011 • GE Vacuums
MY MICROWAVE IS NEAR NEW BUT ITDOES NOT START UP ANY MORE,-
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
Danby Microwave Model DMW 607w 700 watts Does not heat food
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 13, 2010 • Vacuums
No power to microwave
heatman101
Sep 06, 2010 • Vacuums
Manual for GE microwave spacemaker oven GE proffile
here is a website that can help you obtain a manual
Of course they will need the model number of yours
http://www.google.com/search?client=ubuntu&channel=fs&q=manual+for+GE+microwave+spacemaker+oven+GE+proffile&ie=utf-8&oe=utf-8
Sep 03, 2010 • Vacuums
I have an Amana above range Radarange, Model #AMV4204AAB, Serial # 10168958GE. Tonight after running for a 7 minute period and finishing, it would not again start. There is power to it, but various...
  1. Push the power cord all the way into the outlet in case it became loose and is causing the problem. If the microwave still isn't working, check for a blown circuit fuse, and repair it.
  2. Step 2 Check that the controls on the microwave are programmed correctly according to the owner's manual. If they aren't, program them.
  3. Step 3 Close the microwave door firmly. Touch the cook function on the Start Pad, not the timer. Check if the microwave works. If not, continue to step 4.
  4. Step 4 Program the Power Level correctly. If it's not programmed properly, the microwave will cook the food too quickly or too slowly.
  5. Step 5 Use only microwave safe dishes. Make sure food is evenly shaped and defrosted before placing it in the Amana Radarange microwave.
Thanks.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Jul 09, 2010 • Vacuums
Top Sharp Vacuums Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sharp Vacuum Expert? Answer questions, earn points and help others
