SOURCE: Switch settings on stanley garage door opener
check the pin configuration on the back of the Stanley 3200
SOURCE: reprogram key pad for garage door opener
To program the keypad, you will have to press the LEARN button on the back of the garage door opener console and when it begins to flash, enter a new 4 digit code on your keypad and press enter. You should hear a click and see the lights on the opener flash.
SOURCE: How to reprogram Sears Mult-Function Keyless Entry garage opener
On the garage opener that actually opens the door the one on the
ceilling has a green or orange button that is called the learn button
just press and release it you have 30 seconds to punch in a 4 digit
code and when your done press and hold the enter button until the
lights on the garage open blink once or twice then just press the code
again and it will open the door press enter once to reverse the effect
and and twice to stop the door completely.
Hope that helps
SOURCE: have chamberlain security plus 950cb lost instructions.
http://www.chamberlain-diy.com/doityourself/pdfdocs/114A2184.pdf
This web address came from the Chamberlain site. I also needed to relearn my remotes due to a newer car that has a built in garage door opener that needed to be set. I also needed to reset my keypad remote, those instructions I was able to get from the same site. Good Luck
SOURCE: Stanley garage door opener chain screw adjustment
THE ADJUSTMENT IS SUPPOSED TO HAVE A 2ND NUT THE TWO TIGHTEN AGAINST EACH OTHER AND ACT LIKE A LOCK
