Video Game Consoles & Games Logo
Posted on Jul 02, 2008
Error code:51331 - Video Game Consoles & Games
Anonymous
Level 1:
  • Contributor 31 Answers
  • Posted on Jul 03, 2008
Anonymous
Contributor
Level 1:
Answers
31
Questions
0
Helped
5112
Points
41
Wii Error Code 51331 means there is a problem with wireless security.
Make sure your router’s WEP key matches the WEP Key you entered in the Wii.
If your router is using 64-bit encryption, the WEP Key must be 10 characters.
For 128-bit encryption, the WEP Key must be 26 characters.
WEP Keys can only use the characters 0-9 and A-F.
If your router allows more than one WEP key to be entered at a time, make sure the key you’re using is on slot one.
If you double checked the WEP or WPA key with the router and the Wii and they match, but you still receive the Wii Error Code 51331, then MAC filtering may be enabled in the router. You will have to add your Wii’s MAC address to the router’s allowed list. You can do this by logging into your router and going to the “access control, access list, or network filter” settings.
If you still have trouble with Wii Error Code 51331, try changing the wireless router’s channel to 1 or 11. This may increase download speed.
Check Nintendo’s router page for special notes on your router if available. Follow the instructions of the special notes.
Your wireless router must broadcast in mixed or b/g mode and cannot be set to “g” only mode.
1helpful
Nintendo wii error code 51331
Wii Error Code 51330 and 51331, and 51332 means incorrect WiFI password and the wrong password was typed in.
Have error code 51331 on wii for netflix will
hi dear you can take help form here and solve this problem yourself
I keep getting an error code 51331. cannot get an internet access on my wii
The link below will go over error 51331 and how to resolve it. This error seems to be caused by a network configuration issue.
Click Here
Regards,
G33k
How do I get my Wii to connect to my internet wirelessly? When I try I get error code 51331
Sorry to hear you are having problems with your wii. According to Nintendo, error code 51331 is:
Error Code: 51331
Unable to connect to your wireless network
This error code is more specific to having incorrect security settings on your wii. Your encryption key is wrong when trying to connect to your wireless internet. Double check your encryption key with your router's settings and try again.
You can see the official support article from Nintendo here:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51331&system=Wii&locale=lang
Error code 51331 keeps showing up what do i do.
Hello rjcs4 and welcome to FixYa. The error code for the Nintendo Wii 51331 means you have a issue with your wireless security. Make sure your routers WEP Key matches that of your Nintendo Wii. This should solve the problem. I hope this was helpful and good luck.
Will not connect to internet error code 51331
Hi there, Error code 51331 means that there is a problem with the security key on your wifi connection. You will just need to through the setup on your console again taking care that you enter the security key the wep/wpa key on the back of your router exactly as it is(ie. Small letter, capital letter, number etc.) hope this helps
2answers
Cant get online through sky broadband
Make sure your router’s WEP/WPA (one or the other not both)key matches the WEP/WPA Key you entered in the Wii.
If you double checked the WEP/WPA key with the router and the Wii and they match, but you still receive the Wii Error Code 51331, then MAC filtering may be enabled in the router. You will have to add your Wii’s MAC address to the router’s allowed list. You can do this by logging into your router and going to the “access control, access list, or network filter” settings.
Error code 51331
If you got error code 51331, this basically means you can't connect to the Internet because of wireless interference.
Try these:
Move your router away from metal objects such as metal cabinets, and place it in a central location in your home.
Do not use other wireless devices while trying to connect to the Internet.
Avoid devices that use a 2.4GHz radio frequency. Look for devices that use a 5.8GHz or 900MHz frequency.
Change the channel on your router to 1 or 11, as these don't overlap.
If you have encyrption on your router, make the WEP/WPA key is correct.
Change the mode on your router to "mixed" or "b/g" mode.
Hope this helps!
Error Code 51331
If you still encounter the Wii Error Code 51331, try doing manually setting up the Wii’s internet connection. You can find your network information to enter into the Wii by doing this:
On your PC, click “Start” and then “Run.”
Type “CMD” into the field that appears to open a new window.
Type “IPCONFIG/ALL” and press “Enter” to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle the wireless router and modem by unplugging both from the wall. After waiting a minute, plug the modem back in and wait another couple of minutes for the modem to initialize. Plug the router in and wait for the router to initialize. Now try reconnecting the Wii to Nintendo WiFi Connection.
Hope this helps a little
Top Video Game Consoles & Games Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
john h
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
