Posted on Dec 26, 2010
Service code sc545 - Gestetner DSm622sp Digital Imaging System
Anonymous
Level 1:
New Friend:
  • Contributor 62 Answers
  • Posted on Dec 31, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
62
Questions
0
Helped
13448
Points
73
Change the thermistors
  • Anonymous Jun 19, 2014
    Press Clear Modes Button then press 107 & press and hold Clear/Stop Button then the screen changes Sp Mode Services then Switch OFF & Switch ON - Thanks
6helpful
4answers
Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
1helpful
My b/w copier suddenly stop working when an error code sc545 appears on the screen and since then it has refuse to work. The moment you turn it on the functional problem error code sc545 appears on the...
You need to check 3 cause for that error:
- hot roller thermistor out of position
- fusing lamp broken (can you see the lamp going on at startup?)
- thermostat broken
If you are just a user, without any technical knowledge, i advise you to call a Ricoh Support Service.
9helpful
Error Code of SC545
That code will not reset by powering off and on. It needs to be reset in the service mode.
My Lanier Super G3 is telling me the service code is SC545. Could you tell me what my problem is?
It's a fuser warm up error. Can only be reset in service mode by a technician after problem is repaired.
4helpful
This is the code on the mach sc 545
Hello sir; The code sc545 means fuser unit temperature too low it can be reset;
press "clearmode" "107" and thenpress and hold "clear/stop" key untill display "copy sp" show up, then turn power off and back on.
1helpful
Dsm622sp error code sc545
Fuser error (warm up error). Needs to be repaired, then the code can only be reset in service mode.
Error code sc545
That's a fuser warm up error. Likely either a blown fuse, lamp or thermistor. Fuser is usually replaced as an assembly, and code can only be reset in "service mode" after the cause is fixed.
Top Gestetner Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
