Whirlpool RBS305PDS Electric Single Oven Logo
Posted on Feb 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is PF error code? - Whirlpool RBS305PDS Electric Single Oven
Hans Pearson
Level 3:
  • Master 2,510 Answers
  • Posted on Feb 15, 2011
Hans Pearson
Master
Level 3:
Answers
2510
Questions
0
Helped
784684
Points
7758
"PF" flashes to indicate that a power failure occurred while the drier was running. Press HOLD TO START to continue the cycle or press OFF/PAUSE to clear the display.
2answers
How to get a pf code off . Just installed new control panel and this code is all that shows up. Help it a frigidaire oven mod. Ples389ech
I appreciate your inquiry, J.J!
From what you have described your Frigidaire oven is displaying an error code of "PF" and you just installed the control panel. A "PF" error code stands for power failure. This could be a possible problem with your control panel and power source. You may need to perform a reset on your oven and you can do that by flipping the household circuit breaker off for at least ten minutes. If this does not help resolve your issue I would recommend having a professional technician out to perform a proper diagnosis and repair. I hope this information is helpful to you. -Matt
My kitchen aid kebc208kss0 is getting the PF error in cool down mode.
\I am not sure y it is giving the PF code because that code is saying there has been a power failure. U could be right in the direction you are thinking.
PF code
Depending on manufacturer and model, PF can mean a number of things. On my stove, PF simply indicates "Power Fail" Yours may, too. You can clear this generally by updating the clock display. To verify that PF does indeed mean power fail for your stove, simply shut off the power for the cicuit than supplies the stove. This can be either circuit breaker or fuses. Turn the power back on after 5 or more seconds and if it displays PF again, you know it means power fail.
Otherwise, please provide the manufacturer and model of you stove for an answer.
Jul 02, 2012 • Ovens
Recieved a PF code and my oven will not work. Is there anything I can do?
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
Pf code
heatman101
I have a Kenmore Ultra Bake Stove, we had a power outage and neither the oven nor burners works. The code on top reads PF 5Ab. What can i do to reset the stove?
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Whirlpool electric range RF361 bxdn 0. error codes? PF?
hi Jon
look on the back of the unit, there should be an envelope that has a paper in it, that paper should tell you what the code means.
Apr 01, 2008 • Ovens
Top Whirlpool Ovens Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
