The stylus pen works by pressure on the tip. Since the tc1100 uses an active digitizer, as soon as you come within range of the screen, the mouse should move (this is called pen-hover), however, if the tip is stuck upwards it will write or click instead just as if you were touching the screen.
Try carefully pulling out the tip using a needle nose pliers or your fingernails if they're strong, and then reinsert the tip gently. This should un-stick it. If this doesnt work, there may be an internal problem with the stylus.
Any idea if a stylus problem can be fixed by HP, or if I should consult my school's tech-support first? The tablets were technically issued through my school to all its students...and I don't know if a warranty exists beyond 1 years for all items (i.e. the stylus in this case).
I've got the same problem. Sometimes the pen continuously clicks. Do you have still a solution for this?
I have the same probllem on my tx2000....did you find and answer
