Toshiba PDR-2300 Digital Camera Logo
A
Anonymous Posted on Sep 11, 2005
Card Error If have a warning message "CARD ERROR" in the LCD Display. what shuold I do?
Anonymous
Level 2:
Novelist:
Scholar:
  • Expert 104 Answers
  • Posted on Sep 11, 2005
Anonymous
Expert
Level 2:
Novelist:
Scholar:
Answers
104
Questions
Helped
16743
Points
306
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Top Toshiba Cameras Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Tony Parsons
Tony Parsons
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
