Toshiba PDR-3320 Digital Camera Logo
A
Anonymous Posted on Sep 11, 2005
Card Error Message
I have a warning message: "CARD ERROR" in the LCD Display. what shuold I do?
Anonymous
Level 2:
Novelist:
Scholar:
  • Expert 104 Answers
  • Posted on Sep 11, 2005
Anonymous
Expert
Level 2:
Novelist:
Scholar:
Answers
104
Questions
Helped
16743
Points
306
1. Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. 2. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. 3. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. 4. The Toshiba PDR-3310 is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. The PDR-3310 may work with some MultiMedia Cards, but is not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
5 Related Answers
Anonymous
  • 104 Answers
SOURCE: Card Error
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Anonymous
  • 104 Answers
SOURCE: Card Error
Anonymous
  • 104 Answers
SOURCE: Card Error
Anonymous
  • 104 Answers
SOURCE: Card Error
Anonymous
  • 4 Answers
  • Posted on Jun 14, 2008
SOURCE: Card Error
Also, I need help in understanding the cards. Like: micro card, mini card, card only etc etc. I inserted a micro card (this come two in pkt. so I inserted bigger card and screen shows "card error"; remove card and insert micro card into big card, reinsert it and was fine. That's why I want to know the difference between them. Thank-you.
Top Toshiba Cameras Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Tony Parsons
Tony Parsons
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
