The F19 error code on an AEG double fan oven typically indicates a problem with the oven's electronic control board. This could be caused by a malfunctioning component on the control board, a loose connection, or a problem with the wiring.
If your AEG double fan oven is displaying the F19 error code and tripping the RCD (Residual Current Device), it is recommended to unplug the oven and stop using it until the problem can be resolved. Here are a few steps you can try to troubleshoot the problem:
- Check the wiring: Make sure all the wires and connections are secure and in good condition. If any of the wires are frayed or damaged, they may need to be replaced.
- Check the control board: Inspect the control board for any visible signs of damage, such as burnt components or loose connections. If you find any issues with the control board, it may need to be replaced.
- Check for debris: Make sure there is no debris or foreign objects inside the oven that could be causing a problem with the control board.
If you are unable to determine the cause of the problem or fix it yourself, it is recommended to have the oven inspected by a qualified technician. They will be able to diagnose the problem and recommend the appropriate repairs.
