Ovens Logo
Posted on Jul 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The microwave seems to be operating on reduced power. It seems to be transmitting a single wave, as only one part of the food is heating and the rest remains cold. It was repaired 4 months ago and had new magnetrons fitted.
Level 3:
  • Master 17,130 Answers
  • Posted on Jul 22, 2011
Master
Level 3:
Answers
17130
Questions
0
Helped
3710726
Points
52372
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Top Ovens Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
john h
Are you an Oven Expert? Answer questions, earn points and help others
