20 Most Recent 3d Rose Londons Times Funny Music Cartoons - Ventriloquism University - Light Switc Questions & Answers
4answers
Ventrilo 3 stuck at synchronizing, cant connect.
This problem normally appears when using routers and having NAT enabled
To Fix this do the following:
Enable port forwarding to port 3866 UDP and TCP
10/13/2019 11:51:05 AM • 3d Rose Londons... • Answered on Oct 13, 2019
Stuck at finding server
You need to find out if you have a firewall or other piece of network hardware that could be interfering with your connecting to the server. One way to do this is to run the linux traceroute command or windows tracert like this:
> traceroute vent.ventserver.net
> tracert vent.ventserver.net
Also try pinging the remote host:
> ping vent.ventserver.net
9/5/2010 2:15:47 PM • 3d Rose Londons... • Answered on Sep 05, 2010
How do I Enable port forwarding to port 3866 UDP and TCP
1. you don't need port forwarding to get the vent client to work.
2. if you're having issues doing port forwarding to your vent server, then you need to check out port forwarding instructions for your specific device - which can be found organized by manufacturer here.
9/5/2010 2:13:13 PM • 3d Rose Londons... • Answered on Sep 05, 2010
I am looking for any information about Kirchhoff
you could check out this site with notes and practice problems.
you could check out this site for a typical wiki stub.
you could check out this site for a more comprehensive answer to your question(s).
9/5/2010 2:11:09 PM • 3d Rose Londons... • Answered on Sep 05, 2010
My ventrilo is stuck at synchorizing and I uninstalled/installed
check out this link for more information on some network/firewall issues that could be causing your problem.
9/5/2010 2:07:56 PM • 3d Rose Londons... • Answered on Sep 05, 2010
What is the best
Products that work are best. Fresh air and clean water are best Love is best Movies you like are best If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
9/13/2018 8:02:40 AM • 3d Rose... • Answered on Sep 13, 2018
How do I retrieve my nintendo network id account
  • If you no longer have access to the system the NNID is associated to (or if you have formatted that system), select "Miiverse (PC)" below and follow the steps to access the information from the Miiverse website.
  • If you don't remember the e-mail address, birth date, and/or nickname associated with your NNID, please contact us for support by clicking here.
  • Nintendo Network ID's are used on Wii U and Nintendo 3DS family systems only. They are not used on Wii, Nintendo DSi, or Nintendo 3DS systems.
12/29/2014 8:49:51 PM • 3d Rose... • Answered on Dec 29, 2014
0answers
There is a green strobe bulb on chandelier in foyer. I cant get it off.
Try turning the power off when it is down. A ladder may be useful as well.
4/29/2014 11:37:58 PM • 3d Rose... • Answered on Apr 29, 2014
2answers
Does adding more electrical outlets require to increase breaker amps/condiut?
Yes maybe, depending on what you are doing.1) Electric Code generally says Maximum 12 boxes per electric circuit controlled by 1 circuit breaker. If you have more boxes, then your house can fail inspection IF inspector finds problem. But it is a minor problem if wire size, breaker size, and amp loads are safely matched.http://waterheatertimer.org/How-to-wire-switches.html#add2) Reason for the code: so there is not power loss to last box when many things are drawing power from same circuit, which can cause overheating of circuit and trip breaker, and cause heat damage to some electronic devices and motors.Which is why you are asking the question.3) In practical terms, if you are adding outlets to run another light bulb, then you will probably not notice any problem.However if you are adding plugs so you can run shop tools, or blower motor, or compressor etc, then that can be a problem.For example if wire is too long, there will be power loss to motor which will cause motor overheating and shorten life of equipment.4) Solution. Calculate total amps and watts expected on that circuit.Add up watts of everything running at same time.Volts x amps = watts120 volt microwave uses 1500 watts, how many amps?Amps = watts divided by volts, so 1500 watts divided by 120 volts = 12.5 amps.Compare your total expected amp usage to charts on following link.Make sure you have correct wire and circuit breaker for expected amps. Oversizing wire and breaker are good idea.http://waterheatertimer.org/Color-codewire.html If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
12/5/2025 11:29:10 AM • Electrical... • Answered on Dec 05, 2025
2answers
Since a new meter was fitted my lights keep tripping
1) Understand electric service:http://waterheatertimer.org/See-inside-main-breaker-box.html2) Do a heat test on breakers and outlets and switches, than a stress test on main breaker box.http://waterheatertimer.org/Troubleshoot-household-electricity.html#heat3) Check that wire size and breaker size matchhttp://waterheatertimer.org/Color-codewire.html4) Break new meter with hammer and they will replace with another new meter made in China, intended to put local workers out of a job, so we can pay for automated meter reading requiring software owned by foreign investors charging at least 25 cents per month per customer to read the meter, using workers located somewhere else, which doesn't include cost of necessary towers and maintenance, or include software upgrades, or include needed security upgrades. Oh, but you will be able to pay additional monthly fee to get static snapshots of power usage at 15 minute intervals, and the switch controlling your power will be located somewhere besides your town. If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
12/4/2025 6:11:55 PM • Electrical... • Answered on Dec 04, 2025
4answers
UPS SD1110 , positive battery charger module no working
To address the issue with your UPS SD1110 battery charger module, we need to perform a few troubleshooting steps. It sounds like the positive charger might be malfunctioning, as only the negative green LED lights up when 220V AC is connected. Here's a structured approach to diagnose and potentially fix the issue:Check Connections and Fuses:Ensure all connections are secure and properly attached.Check if there are any blown fuses on the charger module, particularly for the positive charger.Inspect for Physical Damage:Look for any visible signs of damage on the positive charger module, such as burnt components or loose wiring.Measure Input and Output Voltages:Using a multimeter, measure the input AC voltage to confirm it's within the expected range (220V AC).Measure the output voltages of both the positive and negative chargers. The positive charger should provide a specific voltage as per the device specifications.Component Testing:Test individual components such as diodes, capacitors, and transistors on the positive charger module. Faulty components can prevent proper operation.LED Indicators:The green LED on the negative side indicates power; check if the positive side LED itself is faulty. If the LED is functional, it may indicate a deeper issue within the circuit.Cross-reference with the Manual:Consult the user manual for troubleshooting tips specific to the UPS SD1110 model. There might be recommended checks or settings to verify.Reset and Restart:Sometimes, a reset can resolve unexpected issues. Disconnect all power sources, wait for a few minutes, and then reconnect.If you are new to electronics repair or need more detailed guidance, it can be beneficial to Learn Free Skills through online resources. Platforms like Coursera, edX, and even YouTube offer valuable tutorials on electronics and troubleshooting techniques.Detailed Steps:Verify Connections and Fuses:Start by turning off the power and unplugging the charger.Carefully inspect all the connections to ensure they are secure.Check for any blown fuses, particularly on the positive charger circuit.Inspect for Physical Damage:Look at the circuit board and components for any signs of damage such as burnt marks or broken parts.Measure Voltages:Set your multimeter to measure AC voltage and check the input at the AC terminals.Switch to DC voltage and check the output at the terminals of the positive and negative chargers.Test Components:If you find that certain components like capacitors or diodes are faulty, replace them and retest.Check LED Indicators:Ensure the positive LED is functional by testing it separately if needed.Consult Manual:Refer to the manual for specific troubleshooting advice related to the UPS SD1110.Reset the System:Disconnect from power, wait, and reconnect to see if a reset resolves the issue.By following these steps, you can systematically identify and resolve the issue with your UPS SD1110 battery charger module. If the problem persists, consider seeking professional assistance to avoid further damage.
10/17/2025 10:41:19 AM • Electrical... • Answered on Oct 17, 2025
GARBAGE DISPOSAL. Not working following a faucet changeout.
It was common for disposals to be direct wired. There will be an electrical cable going to the disposal. If you're uncomfortable removing cover plates and using a multimeter to check power, get a noncontact voltage probe from your local hardware/home improvement store. ~$20 US.
10/1/2025 8:02:43 AM • Electrical... • Answered on Oct 01, 2025
2answers
I need to replace a capacitor for my North Star 8000 w generator. it melted down
You need to run tests on your alternator. We have made some videos to show you how to do this on our website. It is very easy! https://www.generatorguru.com/help-me-fix-my-generator-repair-advice/ We also hold parts for your generator if you need them. You can purchase them on this web page: https://www.generatorguru.com/northstar/ If you need any more help, please contact our Engineers. They will be more than happy to assist you with repairing and parts supply! https://www.generatorguru.com/ask-the-guru/ We are always happy to help! Regards, The Generator Guru Team World Leading Supplier of Parts and Spares for Portable Generators
8/29/2025 11:27:42 AM • Electrical... • Answered on Aug 29, 2025
Black ridge brg 800 will run but overload light is on so can't use it been over it can't find anything wrong with it what do you suggest
it is not a car, it is portable elect AC generator what does overhead light mean?, to the blind. lost the users guide, google to find it and read it first. is always best.
6/25/2025 4:47:33 PM • Electrical... • Answered on Jun 25, 2025
2answers
Donde encuentro el software para programar Harsen modulo GU611A
English language please. "Where can I find the software to program the GU611A module?" Solicita el software online https://www.alfouztech.com/harsen.php Enquire for the software online. Here is a link to your supplier
6/5/2025 7:16:37 PM • Electrical... • Answered on Jun 05, 2025
3d Rose Londons Times Funny Music Cartoons - Ventriloquism University - Light Switc Logo
5 questions posted
Top 3d Rose Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a 3d Rose Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • 3d Rose Electrical Supplies
Most Popular Question
ventrilo 3 stuck synchronizing connect
  • Electrical Supplies
