20 Most Recent Air Intake Kit - 9921B Questions & Answers
Truck wont stay running after installing spectre 9921R kit
uninstall spectre 9921r kit
3/4/2014 3:02:29 PM • Air Intake Kit -... • Answered on Mar 04, 2014
Truck wont stay running after installing spectre air filter kit 9921
have you removed all packaging??
3/4/2014 4:38:37 AM • Air Intake Kit -... • Answered on Mar 04, 2014
Astrostart remote car starter
so bought a used car with this hack installed so in fact you do not know if it ever worked correctlynor if installed correctly, mechanics hate them , so sure some one pushes fob button working under the hood.RTM read the manual first then do the fob learn after a new battery installed in the fob.if still dead it needs servicehere is why:Ive answered this vast times here. ( it can be easy or real hard) dead fob battery tops easy list)2nd poster the manual covers that, new bat , do the RE-learn fob act, in the manual, no model told.the OEM factory version are even way more complex and strict and safer.Remote starting is risky.....RSdoes the local in cab , ignition keyed crank starting work ?, not told this key fact.The remote start (had on hacks) come in vast models, none told by you at all.just the makers name , if you ask them directly they have answers for sure.by model.seems they have over 50 models sold. just them.we are blind here can't read the model if your KIT.get the model, # then get the manual from them same modelthen read the manualon the page called TROUBLE (yes it wants to fail as they all do)top causes. fuses blownwired in wrong, Installed wrong.relays bad for it.car in in PARK, the PRNDL switch must work, to tell the RS to allow cranking.if that wire falls off the RS is now dead.at RANDOM answer nextRS-611model guessing of VAST 2007 made so may be here.hand brake switch bad (parking brake) shows not set.park switch and hand brake switches must work. telling RS car is safe to crank and run.some countries and states or laws , either ban this hack or have a huge list of restrictions.here is OEM rules now. (mostlywindows up.all conditions above not false.engine DTC errors not presentengine idle controls not dead DTC errorstranny errors not present for SURE.doors not locked. they must be. to be safe.The car and engine and tranny must be error free. Or OEM RS fail. (for sure by many laws world wide or state wide) in my state door open running cars are illegal, see USPS guy key off to put boxes on porch.???un-attended running. (this law prevents easy as pie, thefts)RS-611 will end the run after x minutes, the installer chose. 18min max gas or 2 times that dieselthe remove fob battery not deadthe REMOTE is programmed for just this car, if lots its programming, it fails see manual for learn mode.the first manual is devoid of troubleshootingso ask them why, or as for a good manual that covers trouble.there are more restrictions , but that depend on the 50 models of RS and the year it was installed.the newer years are more strict.try a new fob battery first.some models use two CR2016 coin cells stacked, do not reverse them.the time limit keeps folks from CO poisoning , them in the garage or living above this garage in a condo.the silent killerr CO GAS is !! "carbon MonOxide GAS"THE RS brain cant see the garage door open. oops.
5/1/2026 2:04:39 PM • Vehicle Parts &... • Answered on May 01, 2026
What is my suffix code mean FII5M
Based on the format of Chevrolet/GM engine stampings, the code is likely F1115M (using the number '1' instead of the letter 'I' for the month/day). F = Flint, Michigan (Engine Plant) 1115 = November 15 (Date of assembly) M = Suffix code indicating the specific engine configuration (e.g., cubic inch, horsepower, transmission type). Without knowing the year of your vehicle, a precise match for 'M' is difficult, but in the 1960s-1970s, it often refers to a V8 passenger engine. Recommendation: Check the casting number on the rear of the block (near the bellhousing) to verify if it is a 283, 327, or 350. The "I" is almost always a "1" in these codes, as they used numbers for dates (e.g., F1115 = November 15).
3/3/2026 7:46:54 AM • Vehicle Parts &... • Answered on Mar 03, 2026
The remote wont open the trunk but everything else works
It sounds like a classic glitch with these older systems, but since your doors still lock fine, the remote itself is probably okay. The first thing I'd try is holding the trunk button down for a solid 3 to 5 seconds; these alarms usually need a long press so you don't accidentally pop the trunk while the keys are in your pocket. If that doesn't do it, listen closely to the trunk while you press the button. If you hear a "click" but it doesn't open, the latch is likely just stuck and needs a little WD-40 or a manual adjustment. If it's dead silent, you're probably looking at a blown fuse tucked under the dash or a worn-out actuator, which is just the little motor that physically pulls the trunk wire for you.
12/25/2025 5:06:19 PM • Vehicle Parts &... • Answered on Dec 25, 2025
Getronic gt482 gt82n
Per cambiare la batteria interna del telecomando Getronic GT482/GT82N, di solito bisogna aprire l'alloggiamento del telecomando facendo leva dove c'? la fessura di giunzione della scocca, rimuovere la vecchia batteria (di norma una CR2032 o simile a bottone) e inserirne una nuova con la polarit? https://10-0-0-1.net/ corretta (+ verso l'alto).
12/18/2025 11:30:41 AM • Vehicle Parts &... • Answered on Dec 18, 2025
3answers
Metal Detector Manuals
Will any metal detector manual serve, or do you have a specific make and model in mind?
8/28/2025 2:38:12 PM • Vehicle Parts &... • Answered on Aug 28, 2025
Bypass dynamco immobiliser
Bypassing a Dynamco immobilizer involves complex and sensitive modifications to a vehicle's security system. It's typically designed to prevent unauthorized use of a vehicle, so bypassing it without proper authorization or expertise can cause legal issues and void warranties. If your immobilizer is malfunctioning, consult a professional automotive locksmith or an authorized service center for safe troubleshooting and repairs. If this is for legal purposes, please consult your vehicle's manual or reach out to Dynamco's support for assistance.
12/6/2024 6:12:57 AM • Vehicle Parts &... • Answered on Dec 06, 2024
Prestige alarm now headlight issue
I think yiu should get it repaired
9/27/2024 8:31:31 PM • Vehicle Parts &... • Answered on Sep 27, 2024
2answers
P034062
10 year old question! P034062 The position sensor for the intake camshaft (cylinder bank 1) has an electrical fault.Oct 12, 2022
Mercedes P034062: Intake Camshaft Position Sensor Q&A
JustAnswer https://www.justanswer.com > Mercedes
8/31/2024 6:10:23 AM • Vehicle Parts &... • Answered on Aug 31, 2024
2answers
Need to reset factory alarm on 1995 Mercedes Benz E320
U didn't explain y u wanna reset the immobilizer system.. Is it ur MB immobilizer system lock n car can't start or ur remote can activate ur centre locking system..? If yes try dissemble the mob key ( key with a big round button ) n use the key lock/unlock rear trunk n press ur mob key point to rear mirror at the same time..
8/17/2024 11:26:08 AM • Vehicle Parts &... • Answered on Aug 17, 2024
2answers
1944c Furuno radar array won't spin 7 years old. Just beeping
try some troubleshooting, check power supply; ensure the radar is receiving adequate power. check the connection and fuses. reset the system. check error codes inspect the antenna
8/6/2024 10:15:57 PM • Vehicle Parts &... • Answered on Aug 06, 2024
2answers
Is it good to wrap new vehicles?
Yes, you should go for car wrap, it has many advantages like a high quality film will help you to prevent color fading, flying glass splinters during accidents and heat protection etc. A nice Auto folie will enhance the appearance of your vehicle.
7/8/2024 6:09:16 AM • Vehicle Parts &... • Answered on Jul 08, 2024
Gemini 7350 alarm
Your question is ...................................
7/7/2024 8:11:45 AM • Vehicle Parts &... • Answered on Jul 07, 2024
Start error on dash for mercedes s420
The "Start Error" message on the dashboard of a Mercedes S420 typically indicates an issue with the vehicle's anti-theft system or the immobilizer. Here are some steps you can take to troubleshoot and potentially resolve this issue:
  1. Check the Key:
    • Ensure that the key you are using is the correct one for the vehicle. Try using a spare key if available.
  2. Battery in the Key:
    • Replace the battery in the key fob if it is low or dead. A weak battery can cause communication issues between the key and the car's immobilizer system.
  3. Check Fuses:
    • Inspect the fuses related to the immobilizer and starting system. Refer to the owner's manual for the location of these fuses.
  4. Reset the System:
    • Disconnect the car battery for about 15 minutes to reset the vehicle's electronic systems. Reconnect the battery and try starting the car again.
  5. Check the Antenna Ring:
    • The antenna ring around the ignition cylinder reads the key's transponder chip. Ensure it is properly connected and not damaged.
  6. Check for Error Codes:
    • Use an OBD-II scanner to check for any error codes that might give more insight into the issue.
  7. Professional Diagnosis:
    • If the problem persists, it may be necessary to have the car diagnosed by a professional mechanic or a Mercedes dealership. They can use specialized equipment to pinpoint the issue.
Potential Causes:
  • Transponder Key Issue: The transponder chip in the key may be damaged or not properly communicating with the car's immobilizer.
  • Immobilizer System Fault: There could be an issue with the car's immobilizer system, which prevents the car from starting.
  • Electrical Problems: Issues with the car's electrical system, such as a faulty ignition switch or wiring problems, can trigger the "Start Error" message.
7/4/2024 7:46:36 PM • Vehicle Parts &... • Answered on Jul 04, 2024
2answers
Change tag light bulb 2003 nissan marono
If you are referring to the small light for the rear number plate you need to access it from the inside of the vehicle. You will need to open the trunk (boot) and remove the plastic trim panel on the tailgate itself. You will be able to get to the bulb holder from that side.
6/26/2024 10:35:26 AM • Vehicle Parts &... • Answered on Jun 26, 2024
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
3/28/2024 3:46:39 AM • Vehicle Parts &... • Answered on Mar 28, 2024
Peugeot expert central locking not working
A faulty central locking system might be due to several reasons, such as a blown fuse, faulty solenoid, or electrical wiring issues. Also, it's good to remember the fault might not be with the central car locking system but the key fob instead; over time, fobs require battery changes.
3/24/2024 2:38:44 PM • Vehicle Parts &... • Answered on Mar 24, 2024
3answers
What is hashtag
hash·tag noun
  1. (on social media sites such as Twitter) a word or phrase preceded by a hash or pound signand used to identify messages on a specific topic."spammers often broadcast tweets with popular hashtags even if the tweet has nothing to do with them"
    • the hash or pound sign (#)."Hunt mistook an @ for a hashtag while tweeting derogatory thoughts about him"
2/25/2024 9:46:45 AM • Vehicle Parts &... • Answered on Feb 25, 2024
Air Intake Kit - 9921B Logo
2 questions posted
Top Spectre Vehicle Parts & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Spectre Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Spectre Vehicle Parts & Accessories
Most Popular Question
truck wont stay running after installing
  • Vehicle Parts & Accessories
