20 Most Recent Bionaire BSF1731RC Stand (Pedestal) Fan Questions & Answers
Bionaire Dual Fan, one fan is not working?
Take it apart and swap the fans over. If the none working fan still doesn't work, you need a new fan motor. If the none working fan does work, you have a wiring issue. https://www.google.com/search?q=Bionair+Dual+Fan ..
7/1/2021 7:21:25 PM • Bionaire... • Answered on Jul 01, 2021
2answers
Oscillation works but motor doesn't
try tofix the axle with some glue or so
10/4/2014 6:25:11 PM • Bionaire... • Answered on Oct 04, 2014
The lights come on but the fan blade doesnt turn
Check the thermal fuse located inside the motor fan winding wire. Check the crystal oscillator and micro-controller located in the printed control board of the fan. When it is replace with similar type, the fan will function again and ready to be use.
Thanks for asking.
7/9/2011 11:50:12 AM • Bionaire... • Answered on Jul 09, 2011
The fan motor works but
ossilate gear assembly damage need replacement
4/9/2011 11:47:21 PM • Bionaire... • Answered on Apr 09, 2011
Well, we loved our fan
Hi this is a very common problem with fans, now what has happened is that over time dust has got into the part that the fan blades spin on and this has dried up the grease that prevents the fan from stopping like it has done, using it like this will cause it to over heat and this will then cause the motor to short out and stop working all together.
now if it hasnt all ready shorted out then their is one thing you can try, make sure its not plugged in then you need to remove the cover that stops you touching the fan once this is removed you will be able to see how the fan comes off its drive, you need to take the fan off and give the part its spins on a good clean then get some grease or vaseline and give it a coating with this then put it back together this should then make your fan work unless the motor has all ready over heated.
you need to grease all the moving parts and then this will get the fan working again dont try switching it on whilst you have it in pieces make sure you put it all back together before switching it on, also check the fuse in the plug as this will blow if it has over heated.
let me know how you get on or if you need further assistance ok
8/23/2010 8:31:15 PM • Bionaire... • Answered on Aug 23, 2010
Our fan used to blow air excellently but now it
maybe the fan reverse connection.
6/28/2009 9:42:52 PM • Bionaire... • Answered on Jun 28, 2009
Fan blades are filthy!
put motor oil to the midst of your fan blade may there are lots of rust inside then wait 5 hours then try to pull again patiently...
4/16/2009 7:46:10 AM • Bionaire... • Answered on Apr 16, 2009
Bionaire BSF1731RC Stand (Pedestal) Fan Logo
37 questions posted
Top Bionaire Dryers Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
View Most Popular
Bionaire Dryers
  • Bionaire Dryers
Most Popular Question
loved our fan
  • Dryers
