20 Most Recent Bionaire BT40 Tower Fan Questions & Answers
How do i check the fuse on a bionaire model
There are no user serviceable parts in that fan.
6/30/2016 12:15:54 AM • Bionaire BT40... • Answered on Jun 30, 2016
0answers
Bionaire bt16 towerr fan not working. Only slight
Possible that the capacitor is weak and so does not power the coils to turn rotor. you will need to check the free movement of the blades, is no use some oil to free the rotor blades, if the blades are free then check the continuity of the coils specially if they are heating up , if so check the capacitor.
7/5/2011 9:56:12 AM • Bionaire BT40... • Answered on Jul 05, 2011
2answers
RE: Bionaire BSF1620RC Pedestal Fan - blades won't turn. I have had this fan for about 4 years - 2 of which the fan has been stored. It was well protected so I don't know why it isn't working. but th
These run very small motors with low "starting torque" If the fan hasn't been run for a long time, its possible that it has jammed up or got tight from just sitting there. Being careful, turn on the fan and spin it in its usual direction by hand, it should start running. If you cannot spin by hand, it may have seized up which will require you to strip and lube the motor. If you manage to get the fan spinning , let it run on high fan speed for an hour or so, it should free up and then be OK again. A small spray of WD40, CRC or similar spray can lube on the fan shaft where it disappears into the motor may assist.
2/3/2015 4:25:48 PM • Bionaire Dryers • Answered on Feb 03, 2015
0answers
Btf4010
Be the first to answer 7/13/2014 3:07:00 AM • Bionaire Dryers • Posted on Jul 13, 2014Be the first to answer
Bionaire BT40 Tower Fan Logo
8 questions posted
Top Bionaire Dryers Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
View Most Popular
Bionaire Dryers
  • Bionaire Dryers
Most Popular Question
check fuse bionaire model
  • Dryers
