20 Most Recent
Frigidaire FAD504TDD Dehumidifier Questions & Answers
How to remove cover
Good Afternoon Friend, thank you for your post!
I see that your question is listed under Frigidaire dehumidifier (FAD504TDD) and that you would like to know how to remove the cover. Please help me understand if you are speaking about the bucket and if you are trying to reach the filter or the components? With this information I can provide the correct instructions to you. Thank you! - Z
Why is my Frigidaire Dehumidifier kicking the breaker off
Hey friend, thank you for your post!
Based off the information you have provided I would recommend trying a different outlet within the home to make sure it is not that breaker. If testing your appliance on another outlet does not correct the issue it could be a power cord or control panel problem within your dehumidifier. Are you still under warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your dehumidifier and the procedures to any potential remedy. -Matt
Why compressor comes on for a second then shuts off
Good Morning Friend,
I understand that the compressor on your Frigidaire dehumidifier, model# FAD504TDD, comes on for a second and then shuts off. First, make sure that when you are first turning your dehumidifier on that you put it in continuous mode. After about 3 days of continuous mode, set your appliance to the humidity level you would like. Secondly, the "Compressor" circuit has an automatic 3 minute time delayed start if the unit is turned off and on quickly. This prevents overheating of the compressor and possible circuit breaker tripping. Thirdly, make sure the tank is fitted correctly otherwise your dehumidifier will not turn on. Lastly, make sure your dehumidifier has sufficient clearance to operate. There should be a minimum of 12 inches clearance around your dehumidifier. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dehumidifier status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Starting tripping circuit breaker
Good Afternoon Dennis - Often when this occurs, it is
because there are too many appliances on the circuit or something may have a
weak or poor breaker. Try plugging the unit in a different location or on its
own circuit. If the issue continues, then it could also be possible that
something shorted within the unit. So in this case, because it is a smaller
appliance, repairs are often more costly than the actual unit replacement. You
may want to check and see if your dehumidifier is still under warranty and if
so, reach out to the manufacturer to determine the exact warranty coverage.
Thanks for allowing me to help you.
Just bought this unit and it wont drain out the
When this happens with a brand new unit, there are a couple of things that can be causing it:
The drain hose/garden hose you're using is to long. It should not exceed 48" in length and must slope down and straight to the floor drain.
A piece of packing material or debris is in the hose concector and inner tubing. To remove this clog, turn the unit OFF & unplug it. Then Using an appropriately sized, 18" long, plastic
Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing.
Continue to push it in until you reach a bend in the tubing. You will
need to gingerly work the Zip Tie past this bend, until it either
bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip
Tie back out while rotating (twisting) it. This will breakup any clogs.
As you reach the inserted end of the Zip Tie, be prepared, as some water
may follow. Reconnect the hose, plug the unit in and turn the Master
ON/OFF Switch to ON. Set the humidity extraction level to 35% . Allow the unit to run,
while you monitor the hose end for water flow. Be patient, as it may take 5 to 10 minutes to start flowing.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers.
I hope this helps you to troubleshot & solve the problem. Thanks for choosing FixYa.
I have a hose discharging water from back . but
The clog is not in the hose. It's in the hose connection tube inside the unit. To unclog it use an 18" long plastic Zip Tie or something similar that is flexible and will fit into the hole. NO wire coat hangers though. Gingerly work it into the hose connection hose, until you reach a bend in the tubing. This is the tricky part, as you have to get past this bend. Be careful and work it past the bend. Once the Zip Tie bottoms out or you run out of Zip Tie, slowly pull it back out while rotating it. This will dislodge the clog. Once the Tie is almost all the way out, be prepared for water to follow.
One other thing. If the unit stops operating check that the bucket full light is illuminated. If it is remove the bucket and empty the contents and then check the seal between the hose and the drip tray. If there is a small leak then replace the hose gasket and re-tighten the hose.
FYI - Your humidifier does not have a pump. It relies entirely on gravity to drain, when you use the hose connection.
That should solve the problem.
Frigidaire FDD25S1 won't turn off.
Here are some steps you can try:
Check the Hose Connection: Since you mentioned that you have a hose connected, ensure that it's securely attached. Sometimes a loose connection can cause the unit to continue running even when the bucket is full.
Inspect the Drain Bucket and Sensor: Make sure the drain bucket is properly positioned and seated. Additionally, check if there's any debris or dirt blocking the sensor that detects the water level. Clean the sensor if needed.
Reset the Unit: Unplug the dehumidifier from the power source for a few minutes, then plug it back in. This can sometimes reset the control board and resolve any glitches.
Check for Error Codes: You mentioned that the digital display reads "CO." Refer to the user manual or Frigidaire's troubleshooting resources to identify what this error code means. It could provide insights into the issue.
Inspect the Control Panel: Look for any buttons or settings related to continuous mode. While some models may not have a specific switch for continuous mode, there might be a combination of buttons (e.g., holding down two buttons simultaneously) that activates or deactivates it.
Review the User Manual: If you still can't find a solution, consult the user manual that came with your dehumidifier. It should provide specific instructions on how to operate and troubleshoot your model.
If none of these steps resolve the issue, consider reaching out to Frigidaire customer support
Meaning of "F1" in a Frigidaire Dehumidifier model FFAD5033R1?
For the slightly larger model, FFAD7033R1, F1 turned out to be the humidity sensor. This can be accessed by removing just the back panel.If you have a soldering iron for less than a nickel you can just replace the NTC Thermistor (small orange resistor 10k) on the small PCB. See attached image below.In the image below just to the right of the white sensor you can see I removed the bad thermistor..
