20 Most Recent DSC Pc500rk Pc Classic Pc 500 Rk Keypad ....new In Box Questions & Answers
I replaced the battery in my house alarm but I think there is a low beeping once in a while from the back up battery panel. Can a bad DSC PTD1640u transformer cause the panel to beep?
The transformer will either work or not and if it doesn't work, I would think you would have issues including a permanent soounder. Disconnect the battery and if it still works, the transformer is OK. Perhaps the battery is low voltage.
6/18/2024 3:50:08 PM • DSC Home... • Answered on Jun 18, 2024
DSC Power 832 blank keypad and cant shut off siren?
If the keypad on your DSC Power 832 goes blank when the alarm is tripped, there could be a few reasons for this issue. Here are some troubleshooting steps that you can try:
  1. Check the power supply: Make sure that the power supply to the alarm system is working correctly. Check the power connections, and ensure that the battery is charged. A weak battery or poor power connections can cause the keypad to go blank.
  2. Check the keypad connections: Check the keypad connections to ensure that they are secure and not corroded. Corroded connections can cause intermittent issues with the keypad.
  3. Check for damaged wiring: Check the wiring to the keypad to ensure that it is not damaged. Damaged wiring can cause the keypad to lose power intermittently.
  4. Test the keypad: Test the keypad to see if it is working correctly. Press each key on the keypad to ensure that it is responding. If any keys are not responding or are responding intermittently, there may be an issue with the keypad itself.
  5. Check for a faulty control panel: If the above steps do not resolve the issue, there may be a problem with the control panel. A faulty control panel can cause intermittent issues with the keypad.
If you're unable to troubleshoot and resolve the issue on your own, it may be best to contact a professional alarm system technician to diagnose and fix the problem.
2/28/2023 4:47:48 AM • DSC Home... • Answered on Feb 28, 2023
2answers
PC 1565 House alarm system trouble
Man, I believe that the best decision for you is just to connect with the specialists from the company that installed you this security system. That will be much better than to search for help here. I have a system from https://ajax.systems// and when I have some troubles with this I always can connect with the specialists that fix any trouble during a day. That is great that their service is working so fast and my house is always under the protection. I also like the quality of pictures on their cameras, that is possible to see all the details of the face, for example.
2/21/2021 8:05:25 AM • DSC Home... • Answered on Feb 21, 2021
What is the master code for a DSC pk5501 alarm
It depends on the alarm dealer that installed it since it was set by them when it was installed. The master code is never left something like 1234. You should call the last company to service the system. You can't typically default an alarm panel to put a code back to default.
5/2/2018 11:22:00 PM • DSC Home... • Answered on May 02, 2018
How to turn the volume up on a dsc powerseries 433mhz home alarm
If you are referring to the siren or keypad tones or anything you can't. If the siren isn't loud enough then it may be a lack of power issue or you may need an additional one. 1 siren is usually adequate for most houses.
5/2/2018 11:19:29 PM • DSC Home... • Answered on May 02, 2018
2answers
My DSC house alarm has no power to keypad or sensors what's wrong
Either there is a fuse blown to.thevaux power or the wire has come loose from the terminal or there is a broken wire. Lastly have you checked to see if the transformer is still plugged into the outlet?
12/16/2017 6:58:42 AM • DSC Home... • Answered on Dec 16, 2017
Pc1555rkz
Could you maybe look for a brand and model on the system? Either on the keypad or on the system box (metal panel somewhere in the house)? Then maybe Google the brand and model, looking for a manual?
5/20/2017 2:27:30 AM • DSC Home... • Answered on May 20, 2017
2answers
How can I find the code number to reset the anti tamper box so as the alarm will work
The code is specific to your device and would ordinarily be known by the person that installed it
2/4/2015 2:47:05 PM • DSC Home... • Answered on Feb 04, 2015
Turn a zone off on DSC 9047 - ADT.com
go to the on screen menu either on camera or dvr
12/5/2014 1:29:41 AM • DSC Home... • Answered on Dec 05, 2014
Reset instalateur dsc panel code
need to know panel type and version
6/25/2014 5:45:58 PM • DSC Home... • Answered on Jun 25, 2014
0answers
0answers
Data io unisite
Be the first to answer 4/15/2014 2:39:07 PM • DSC Home... • Posted on Apr 15, 2014Be the first to answer
Dcs 5501 trouble light
When checking troubles on DSC, *2 brings up the trouble codes and trouble light will flash after pressing *2 1=Service Required (press 1 to get sub codes) 1=Low Battery 2=Bell Circuit 3=System Trouble 4=System Tamper 5=Module Supervision 6=RF Jam Detected 7=PC5204 Low Battery 8=PC5204 AC Failure 2=Loss of AC Power 3=Telephone Line Fault 4=Failure to communicate 5=Sensor (or Zone) Fault --- Press 5 to identify zone/sensor 6=Sensor (or Zone) Tamper --- Press 6 to identify zone/sensor 7=Sensor (or Zone) Low Battery --- Press 7 to identify zone/sensor 8=Loss of Time & Date
4/10/2014 2:47:45 AM • DSC Home... • Answered on Apr 10, 2014
0answers
How do I turn off the motion detector on my
see the below link and have a look at the door chime setting. turn it off as instructed and it should sort out your problem. http://www.myalarm.com/manuals_prog/pc3000p.pdf
11/6/2013 3:23:23 PM • DSC Home... • Answered on Nov 06, 2013
DSC Pc500rk Pc Classic Pc 500 Rk Keypad ....new In Box Logo
4 questions posted
Top DSC Home Security Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Billius
Are you a DSC Home Security Expert? Answer questions, earn points and help others
View Most Popular
DSC Home Security
  • DSC Home Security
Most Popular Question
replaced battery in house alarm but
  • Home Security
