20 Most Recent Ecoquest Fresh Air Air Purifier Questions & Answers
Fresh air yd-700a e001 error
My unit would display e001 and e003 errors. Cleaning the filter and replacing the ceramic ozone plate did not fix it. Ended up taking the board out and inspecting it. Three capacitors were bad. After replacing, the system is working again. badcaps-dgouqi3kw5klmellc443m1pg-3-0.png
2/15/2020 12:26:02 AM • Ecoquest Fresh... • Answered on Feb 15, 2020
3answers
Fan Noise
Your fan motor probably needs additional maintenance, in the way of lubrication.
After removing the unit from power, access the Fan blade and spin with finger. If there is any resistance to note then the spindle running through 2 bearing surfaces needs lubrication.
See the other question/answer to fan removal - motor lube.
If you have any sort of humidity to contend with and have a FreshAir model F1 or earlier different type, they seem to have some corrosion problems after a period of a couple years.
It is just a function of the machine/job that necessitates such maintenance.
11/22/2018 12:06:35 AM • Ecoquest Fresh... • Answered on Nov 22, 2018
The display shows no ice-read owners manual. can anyone help?
You can fix your unit, trade it in for a brand new one or find additional help here: https://freshairpurifiers.net
5/19/2018 9:43:46 AM • Ecoquest Fresh... • Answered on May 19, 2018
Clean focus ecoquest
EcoQuest Focus has no filters or parts to change. Just vacuum. https://freshairpurifiers.net/
5/19/2018 9:27:58 AM • Ecoquest Fresh... • Answered on May 19, 2018
3answers
Ecoquest air purifier uv lamp replacement
If you haven't done so, try replacing the lamp starter.
4/17/2017 3:58:52 PM • Ecoquest Fresh... • Answered on Apr 17, 2017
My Honeywell 5-in-1 True HEPA Tower Air Purifier
Hello, this is Ava with Think Crucial. You may check to make sure that the power cord is correctly connected to the outlet. Test the outlet is functioning properly using another appliance or lamp. Also, check the fuse or circuit breaker. The outlet may be overloaded if other appliances are also in use. Establish and correct the cause of the overload. If none of these works, then there is something wrong with your purifier unit and contact the store where you purchase it or Honeywell for replacement. It is advised not attempt to repair the unit yourself. You can purchase a wide variety of high-quality Honeywell replacement parts for your Honeywell air purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/search?type=product&q=honeywell I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
4/10/2017 12:06:09 AM • Ecoquest Fresh... • Answered on Apr 10, 2017
0answers
2answers
Need a bulb for ecoquest
The Spectrum is no longer being manufactured/distributed by EcoQuest (now Vollara). We don't have extra bulbs in stock, either, but we can try to locate one from another dealer if you'd like. email us at fredandmb@frontier.com. We've been with the company 20+ years.
5/15/2016 1:10:06 PM • Ecoquest Fresh... • Answered on May 15, 2016
No power is getting through to unit.
I have seen it a couple of times where the cable was not properly seated into the back of the machine. If you wiggle the connector, does that make any difference? If this works, then call EcoQuest for an RMA. Is the machine still under warranty? There is a 3 year warranty on FreshAir units, if purchased through an official dealer.
Dutch
5/16/2015 12:33:28 AM • Ecoquest Fresh... • Answered on May 16, 2015
Cleaning Fresh air 2.1
I can help you get a copy of the manual. I can either fax or email it to you. If you email me, I can send you a copy. My email is stevelam at ecobusiness.com.
11/12/2014 11:10:08 PM • Ecoquest Fresh... • Answered on Nov 12, 2014
Where can I find wiring diagram for Ecoquest air purifier. Replaced UV lamp and disconnected wires and cannot remember how to place them.
Try checking the contacts to the ozone plate. Or a wire may be loose--check the contacts and sometimes they need to be cleaned with alcohol.
10/20/2014 4:01:35 PM • Ecoquest Fresh... • Answered on Oct 20, 2014
Ecoquest Fresh Air Air Purifier Logo
311 questions posted
Top Ecoquest Air Purifiers Experts
Kirk Augustin
Kirk Augustin
john h
Anonymous
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
  • Ecoquest Air Purifiers
Most Popular Question
unit will not turn
  • Air Purifiers
