Microsoft Windows 7 Ultimate for PC Logo
Posted on Aug 09, 2011
How Can I Fix directx error - Microsoft Windows 7 Ultimate for PC
Anonymous
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Aug 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
9106
Points
55
What is the error message which pops-up, explain it well so that there is no problem with the clarification of the question.
Fatal error couldn't create a device directx ERROR Message :DDERR UNSUPPORTED
It is a DirectX error. DirectX is needed to play games in Windows.
If it is happening in only 1 game it is most likely the game go to their website support page and see if they have a fix.
If it happening in all games get the latest DirectX package from Microsoft.com
Msvcr100.dll missing I CAN NOT RUN TAKEN5 GAME IN MY FUJITSU
this is your directx problem. the directx plugin which is required to play tekken 5 is missing or not installed in your pc. to fix this problem, you have to install latest directx or update current directx version to latest version. updating directx may take nearly 150 to 200MB.
It has DINPUT.dll error
Dinput.dll errors usually appear when a game or other software program is started. and are caused in one way or another by an issue with Microsoft DirectX.
The dinput.dll file is one of many files contained in the DirectX software collection. Since DirectX is utilized by most Windows based games and advanced graphics programs, dinput.dll errors usually show up only when using these programs.
Solutions:
1. For Dinput.dll not found. Reinstalling Direct X should fix this.
2. Install the latest version of Microsoft DirectX. Chances are, upgrading to the latest version of DirectX will fix the dinput.dll not found error.
Note: Microsoft often releases updates to DirectX without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: The latest version of DirectX should be installed no matter if you're running Windows 7, Windows Vista, or Windows XP. The installation may include DirectX 11, DirectX 10, and DirectX 9 files, but they run side-by-side without problem on all of these operating systems.
3. Assuming the latest DirectX version from Microsoft doesn't fix the dinput.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
Sometimes, though not often, the DirectX version included on the disc is a better fit for the program than the latest version available online.
Uninstall the game or software program and then reinstall it again. Something might have happened to the program files that work with dinput.dll and a reinstall could do the trick.
Restore the dinput.dll file from the latest DirectX software package. If the above troubleshooting steps haven't worked to solve your dinput.dll error, try extracting the dinput.dll individually from the DirectX downloadable package.
4. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
Here is a good link for DirectX info on how to download and install:
http://support.microsoft.com/kb/179113
1helpful
3answers
How do i fix: "Failed to get address for D3DPERF
YOu need to update your DirectX. If still the problem exists then use a system utility software to repair your windows corrupt files, registry files and fix different operating system errors. I would recommend you to use system utility software RegInOut. Hope it works for you.
2answers
I installed skype version 5.0. and after i tried to start it up on my screen appeared fatal error for d3d9.dll
you might have to download and install later/better copy of DirectX
hope this helps
3helpful
Fatal Error:D3DPERF_Set option(d3d9.dll)
That`s a DirectX error. DirectX is a windows driver and manager for games graphics and sound. Update to the latest version of directX to fix any DX regarded error from Microsoft download center. DirectX can also give errors when a Graphic card is not compatible with the game or with the DX version.
23helpful
5answers
When I start IGI i get : (fatal error: Couldn't flip DirectX error
i am usin a nvidia vga card and windows 7 64bit version
when i try igi it shows a error message couldnt flip
directx error
how can i fix this problem??????
2answers
I got problem with d3dx9_29dll was not found.anyone could help?
There are quite a few different ways that d3dx9_29.dll errors may show up on your PC. Some of the more common d3dx9_29.dll errors are listed here:
  • "D3DX9_29.DLL Not Found"
  • "File d3dx9_29.dll not found"
  • "Error while starting game executable - couldn't load DLL file d3dx9_29.dll."
  • "D3dx9_29.dll is missing"
  • "D3DX9_29.DLL is missing. Replace D3DX9_29.DLL and try again."
  • "D3dx9_29.dll not found. Reinstalling the application may fix this problem."
  • "Missing component d3dx9_29.dll"
  • "This application failed to start because d3dx9_29.dll was not found!"
D3dx9_29.dll errors usually appear when a software program, most often a game, is started. Occasionally, d3dx9_29.dll errors will display after a game is loaded but right before the game begins. Unlike many other dll errors which can have complicated causes and fixes, d3dx9_29.dll issues are caused in one way or another by a single issue - some kind of problem with Microsoft DirectX. The d3dx9_29.dll file is one of many files contained in the DirectX software collection. Since DirectX is utilized by most Windows based games and advanced graphics programs, d3dx9_29.dll errors usually show up only when using these programs.
Resolution
Important Note: Do not, under any circumstances, download the d3dx9_29.dll DLL file individually from any "DLL download site." There are a number of different reasons that downloading DLLs from these sites are never a good idea.
Note: If you've already downloaded d3dx9_29.dll from one of those DLL download sites, remove it from wherever you put it and continue with the following steps.
1. Restart your computer if you haven't yet done so.
The d3dx9_29.dll error might be a fluke or one-time issue and a simple restart could clear it up completely. It's unlikely this will fix the problem, but restarting is always a good first troubleshooting step.
2. Install the latest version of Microsoft DirectX 9. Chances are, upgrading to the latest version of DirectX 9 will fix the d3dx9_29.dll not found error.
Note: Microsoft often releases updates to DirectX 9 without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: Are you a Windows Vista user with DirectX 10? Your game or program may still need DirectX 9 files to run properly so give the installation a try. Don't worry, both versions of DirectX can be run side by side in Windows Vista.
3. Assuming the latest DirectX version from Microsoft doesn't fix the d3dx9_29.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
4. Uninstall the game or software program and then reinstall it again. Something may have happened to the files in the program that work with d3dx9_29.dll and a reinstall could do the trick.
5. Restore the d3dx9_29.dll file from DirectX 9. If the above standard troubleshooting steps haven't worked to solve your d3dx9_29.dll error, try extracting the d3dx9_29.dll individually from the DirectX 9 package.
6. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
2helpful
2answers
D3drm.dll promblem
Go to the following site, copy the d3drm.dll and save it to your c:\windows\system32 folder
Top Microsoft Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
