Ecoquest Fresh Air Living Air Purifier Logo
Posted on Jan 30, 2008
Remote control I need a replacement remote and have no idea where to get one
  • cori56 Mar 18, 2008
    I also need a remote control as well as a manual. Can anyone help? I have checked ebay, google and no luck yet.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Feb 18, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
632
Points
Are you still looking for a remote for a Fresh Air?? If so I can tell you where you can get one. vita-man
  • Melissa Petta Sep 20, 2013
    Do you still know where to find a Fresh Air remote for model YD-700A
    I also need a manual
5helpful
Will not turn on - no power at all
If your Breeze was working, but you cleaned it and now it won't turn on, the problem almost certainly is with the reassembly of the components. Go through the following checklist.
1) Make sure the plug in the back is inserted firmly and the wall socket is live.
2) The little switch by the plug should have the "I" end depressed and the "0" end up.
3) Check to make sure the back screen is inserted firmly, depressing the interior safety switch. (It will click when positioned correctly).
4) Make sure the plates are inserted correctly, with the top and bottom in the little grooves and the metal fingers pressing firmly on the screen part of the plate. You may need to twist the white upright posts slightly to align the contacts.
5) Try both the manual and remote controls. If the manual controls work, but the remote ones do not, check to see if the little plastic battery shield is still in the remote. Remove it by pulling on the little tab. If that's not the issue, also try a new battery in the remote. If one set of controls works, but the other doesn't, you may operate the machine with only the working controls and ignore the others.
6) If none of the above suggestions helps, remove the plug in back, and pull out the fuse to see if it is blown. Very infrequently, a sudden powerup or power surge will blow the fuse. If so, replace it with the EXACT same size fuse, available at an auto parts store.
If none of these troubleshooting steps works, then it would appear that the problem is in the computerization. Unfortunately, Vollara (new name for EcoQuest) is no longer servicing nor selling the Breeze. Your only option to get it fixed would be to find a dealer who still has some, along with extra parts, in stock. If you call Customer Service, they will give you some trade-up options. 800-989-2299. Use #16618 if you need a referral number.
None of the buttons operate and no light
It would appear that the machine is not receiving power for some reason.
1) Check the plug in the back. Make sure it is inserted firmly! Determine if the wall outlet is live. Turn the machine on with the manual front switch and with the remote control. If the manual control works, but the remote does not, make sure the plastic shipping shield has been removed from the battery end of the remote. (Just pull on the little tab, if there is one.) Also check the remote battery if the remote controls don't work, but the manual ones do.
2) Make sure the little safety switch has the "I" end depressed and the "0" end out.
3) Unplug the machine, and check the fuse right beside the plug. Replace it with the EXACT same size, available from an auto parts store.
4) Carefully inspect the inside of the machine, looking for wires which are loose, corroded, broken, or missing. If you can't replace these yourself, find an electronics person who can do it for you.
5) Make sure the back screen is inserted firmly so that the internal safety switch is depressed. (You'll hear it click when the screen is in position.)
If none of these troubleshooting steps help, the problem is most likely in the computerized controls or motherboard, and that cannot be repaired. Vollara (EcoQuest's new name) is no longer manufacturing nor servicing the Breeze. However, if you call customer service (800-989-2299) they can give you some upgrade options. Your other solution is to try to find a dealer who has Breezes in stock and who might also have the spare computer components.
Our Air Purifier stopped functioning and no longer turns on. We tried with different electrical plugs and that does not work either. Basilio Rodriguez 1001 E. Clark St. Warsaw, IN...
1) Make sure the plug in the back is inserted firmly.
4) Try both the manual and remote controls. If the manual controls work, but the remote ones do not, check to see if the little plastic battery shield is still in the remote. Remove it by pulling on the little tab. If that's not the issue, also try a new battery in the remote.
5) Remove the plug in back, and pull out the fuse to see if it is blown. If so, replace it with the EXACT same size fuse, available at an auto parts store.
1helpful
How do you replace batteries in freshair remote control . i cant get the back off the remote control.
For the Fresh Air 2.0 or 2.1 remote, its oval shaped.
1. Hold the remote so that that the power button is facing up.
2. Then flip the remote in your hand so you can see the back side.
3. Then with your other hand, side your index finger from the top down the back side of the remote until you finger nail catches the a slot (about an inch from the top of the remote). Right below that slot, is a plastic tab that secures the battery cover. Using your finger nail, pull that tab down about 1/16" away from the remote to unlatch the cover.
4. Lift the cover off the remote, and you should see 2 AAA batteries. Remove the old batteries and replace with 2 new batteries.
5. Align the two tabs on the battery cover into slots on the back of the remote.
6. Gently press the back cover and the latching tab should shap into the remote.
Hope this helps.
3helpful
Front display controls don't work
Sounds like the same problem I had with mine. I had to call and get an RMA number and they replaced the key pad, lcd display, and main board. This repair was covered under warranty. (Under 3 years old) They had it repaired and returned in about a week.
1helpful
2answers
Have HAP422BRC-u Need explantation on the small red window above the name HOLMES does it light up or just a design?
That small red window located ont he fron of the unit is for the infrared remote control that came with your Holes HAP422BRC-U
I Am trying to program the sharper image jumbo sized universal tv remote.I can;t get the Samsung dvd/vcr combo to except any code listed in the instruction manual
I can help you with your Sharper Image remote control.
There are two Sharper Image Remote Controls: a Sharper Image Jumbo Touch Remote Manual, and a Sharper Image Jumbo Remote Manual.
The Jumbo Touch remote does have a learn function which may be helpful in controlling your Samsung DVD/VCR combo.
I hope that helps.
My remote control stopped working
i do apologize for the inconvenience the only thing that i can suggest is the that whole unit will need to be reset. so the machine can connect again with the remote. also make sure that batteries are fully charged. If that doesn't work please let me know.
Top Ecoquest Air Purifiers Experts
Kirk Augustin
Kirk Augustin
john h
Anonymous
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
