Dell 5110cn Laser Printer Logo
Posted on Feb 07, 2011
I have an error : 982.13 Service Engine comm.
2answers
X945e 980.03 service finisher comm - how to fix the issue
The 980.03 communications error on Lexmark X945e indicates a communication problem with the Finisher Controller Card. This usually requires a service call as it deals with cable connections from the finisher, from the bridge unit, the finisher controller card assembly, or the engine card assembly. But try to unplug the printer from power source, replug after 30 seconds. Plug printer straight to power outlet in the wall. Bypass any surge device, power strips or uninterruptible power supply (UPS). These can cause false error messages. If problem continues, I strongly suggest you contact Lexmark technical support or your authorized service provider for assistance. Thanks.
5helpful
I have error codes flashing on my thermostat..it is an american standard model the manual for the therm. has ACOT900AC43UA on front..says to find addedum 18-HD32D2-1/69-2009 for codes i cannot find it...
Error codes from American Standard Pub 18-HD32D2-8, which is a one-sheet document that came with my American Standard air-conditioner:
29 = not listed
129 = not listed
80 = HPCO Fault - problem is in outdoor unit - Desscription: High Pressure Monitor Fault (hard lock out, cycle power to reset)
91 = Communication Inactive Fault - problem is in air handler - Descriptions - COMM Bit Master Clock Error, COMM Heat/Cool Demand Error, Serial Motor Communication Inactive Error
91 = Communication Fault - problem is in furnace - Descriptions: Blower motor no COMM response, Inducer motor no COMM response, Loss of heat/cool demand, Loss of clock signal
91 = Communication Fault - problem is in outdoor unit - Descriptions: Loss of Heat/Cool Demand Message (COMM), Loss of Bit Master (Clock Signal)
91 = Communication Fault - Description: Comm line is dead and no bits have been received.
By the way, I do not recommend American Standard. I've had mine 14 months and it just blew up - the entire control panel blew. My advice to you - think about a different brand.
Nancy
Scottsdale, Arizona
3helpful
7helpful
2answers
HP 3050 Engine Comm error
I have a HP 3050 three in one and I keep getting a engine comm error
2helpful
Engine comm error
reconnect your usb cable to printer to computer.then also try tochange that usb cable if pro remains.
ERROR MESSAGES
nthemba- all the error codes you see indicates phone line condition or error at reciving fax's end. For more details you can refer to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&lc=en&dlc=en&cc=us&product=79477&rule=17804&lang=en
My OS is Windows 3.11 and I am getting communication errors. (Fuji DS, DX and MX digital cameras only)
There is a problem due to comm.drv which is located in system folder of Win.3.11. If the comm.drv is dated Nov.1. 1993 and is 5,968 bytes, please check the property of the comm.drv within your PC. Although the problem is due to the comm.drv, FUJI has prepared a new sdt-7 for Win.311. Please call Customer service at to obtain the sdt-7 or go to the ftp site and download sdt7w31v20.exe. It is important that your PC has Win 32s loaded before install your new sdt-7.
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Rommel Balcita
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
