SOURCE: Error E000001 -0010. The error code is for the fixing assy not getting to the correct temperature in a specified time. The 0010 part of the code is indicating the copier was turned off and back on without resetting the error.Dec 25, 2009 http://www.fixya.com/support/t3708490-error_code_e000001_0010
SOURCE: What does E000020-0010 error code mean?
e0020 is to do with there not being enough toner in the developer unit.
Firstly it may be a good idea to check/change to toner cartridge.
Switch off and disconnect from mains for the next bit.....
If ok remove the developer roller, cover is above the manual tray on the right hand side then once inside dev unit has connectors at either side, check they are properly seated. If you need to remove the dev there are several black screws around a metal plate all need removing. The roller should be black with toner. May need replacing depending on age and usage of copier.
SOURCE: ir8500 error code e000020-0010?
you have to clear this error by doing the following press additional function(*) and 2,8 together) then press additional functions (*)again (you have to do this quickly to get into service mode then you press copier
then you press function
then you press clear
then you press ERR
then you press ok
then turn off the machine and then back on
this is a low toner level detection code
do you have a new toner in the machine?
SOURCE: E000020-0010
you have a problem with your developer or toner add assemblys toneris not going into your dev unit
SOURCE: What is error code E000001-0004 and E000001-0010 f...
there is a good possibility that the main thermistor and the sub thermistor has gone bad or is dirty. also it might need adjusted to be better placed next to the upper fixing roller
